E072 - 0002
  • RainbowVisions
    • 9
    [Error Code] E072 - 0002
    I keep getting an Error Code on a Canon CLC 1110. I swapped out the entire Transfer Drum Case from a working machine and still got the same code. I placed that transfer Drum Case in another machine and it worked fine.. I also cleaned ALL contacts in the rear of the unit as well as on the slide shelf... What is causing this error ? I have checked.. something about a transfer cleaning locking motor. This machine always stop when the paper fed to the tranfer drum.. ?? Can ANYONE Please HELP ? Thanks, PAUL
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5005
    Possible occurrence of E072-0002
    clc1150-004.pdf
    • DANIELCANON
      • Jun 2011
      • 187
      Re: E072 - 0002
      este codigo es ocacionado por el desgaste de los rodillos brush, el motor lo detecta y marca codigo, cambiar los rodillos brush.
      o tambien hay otra solucion que es la de cortar uno de los cables de este motor y empalmarlo con otro para que no detecte la velocidad del motor aca en peru se hace esto para solucionar esbrush.jpgte problema comprobado.
      • vishop
        • Jan 2011
        • 220
        Re: E072 - 0002
        this is still active? or problem solved?
