Canon IR C3100 - paper concertina
  • cyberfix
    • Jun 2011
    • 10
    [Jamming] Canon IR C3100 - paper concertina
    This copier will concertina only the first page (without jamming) after switched off for long period or power save mode during day. New Fuser Unit has made no difference. Any help would be much appreciated.
    Paul
  • Starion
    Tech
    • 58
    I've had issues with the flap (part 25 on the pic below) sticking to the pads at each end, and jamming the first time the machine is used every day. We have replaced the pads with pieces of velcro, new pads, or even just wrapped tape around them as a short term fix.
    FIGURE 140 of the parts manual:
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5013
      Starion is very close but we need to know JAM code to be shore.
      • mrfixit51
        Lead Service Technician
        • 1975
        I have been even more frugal on this repair. I just strip the old pads off and leave it be. The pads are only there for noise reduction, and the noise is so very quiet as to be a non issue on the machines I have seen...
        • cyberfix
          • Jun 2011
          • 10
          Re: Canon IR C3100 - paper concertina
          many thanks guys, removed the pads and solved the issue.
          • mrfixit51
            • 1975
            Sometimes the easy fix is the best fix...
