Greeting to all,
I need help.
I just help my friend to replace the canon IP4000 the part.
I replace the logic board and purge unit and the machine initially was ok but after i fix up the cover and switch on,there is no power supply.
Any configuration need to be configure when change the logic board?How to check the ouput supply?
hank you in advance
I need help.
hank you in advance
