Canon IP4000
  • Peter Sim
    • Sep 2008
    • 445
    Canon IP4000
    Greeting to all,
    I need help.
    I just help my friend to replace the canon IP4000 the part.
    I replace the logic board and purge unit and the machine initially was ok but after i fix up the cover and switch on,there is no power supply.
    Any configuration need to be configure when change the logic board?How to check the ouput supply?
    hank you in advance
    • 16083
    Originally posted by Peter Sim
    Greeting to all,
    I need help.
    hank you in advance
    iP4000 Service Manual.pdf
    Notes on replacement----Before removal of the logic board ass'y, remove the power cord, and allow for approx. 1 minute (for discharge of capacitor's accumulated charges), to
    prevent damages to the logic board ass'y.
    - Before replacement, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the bottom case unit or the ink absorbers when replacing the logic board ass'y.
    Logic board ass'y-
    After replacement:
    1. Initialize the EEPROM.
    2. Reset the waste ink counter.
    3. Set the destination in the EEPROM.
    4. Correct the CD-R and automatic print
    head alignment sensors
    5. Perform the print head alignment in
    the user mode
    Operation check-----
    - EEPROM information print
    - Service test print
    - Printing via parallel or USB connection
    - Direct printing from a digital camera
    EEPROM
    initialization-At logic board ass'y replacement
    (EEPROM settings)-To initialize settings other than the following:
    - USB serial number
    - Destination setting
    - Waste ink counter
    - CD-R correction value
    Destination settings-At logic board ass'y replacement
    (EEPROM settings)-To set the destination.
    CD-R sensor /automatic print head
    alignment sensor correction------ At logic board ass'y replacement
    (EEPROM settings)-To correct the CD-R and automatic print head alignment sensor.
    Print head alignment-- At logic board ass'y replacement
    To ensure accurate dot placement-
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Why did you replace logic board and purge unit in the first place?
      • Peter Sim
        • Sep 2008
        • 445
        Thank you for the reply,I must apologize first ,the model that i replace parts is IX4000,not the IP4000.Is the manual are the same?
        To Mr teckat & Zoraldinho,first when i on the printer,the printer carriage and purge unit are not moving.So i decide to order logic board and purge unit ,but i didn't order the ink absorbers.
        I think is the ink absorber that cause the printer no power.Is there any thing that can be reset? or need to replace another logic board and ink absorber together?I need the advice and tutorial from both of you.
        Thank you in advance.
        • zoraldinho
          • Mar 2008
          • 5018
          ix4000_5000-sm.pdf
            • 16083
            • Peter Sim
              • Sep 2008
              • 445
              Re: Canon IP4000
              Thank you very much
              • zoraldinho
                • Mar 2008
                • 5018
                Re: Canon IP4000
                Thank you very much
