Ir6570 e202-0002
  • repeatcopiers
    • Sep 2008
    • 591
    Ir6570 e202-0002
    When making 2 sided copies, job completes then gives E202-0002 code and requires shut down. Doesn't do it on 2 sided prints, just copies. 1 sided copies and prints work fine as well. Replaced reader controller board and cleaned sensor. Any ideas.....doesn't make since that the motor would be bad, right, since everything else is fine? If you are running 50 2 sided copies, it makes all of them and then throws this code after the last one. My tech is leaning towards something in the feeder even though code says hp sensor, motor or pcb..any ideas?
  • gensys
    • Jan 2011
    • 323
    202 > There is a scanner HP error (home position)
    See lasts jammings codes....
    Check all sensors in service mode......& clear
    Check motor in service mode...... or power tester (motor vol. & R-Om )
    Most likely dirty sensor
    See attach.
    The Road will be Mastered by >>> the Going...
    • teckat
      • 16083
      check the reader memory
      remove/clean-re-seat the ROM on the Memory pcb board
      • repeatcopiers
        • Sep 2008
        • 591
        Re: Ir6570 e202-0002
        See attach.
        Ok we have replaced the hp sensor, motor and board. We also replaced the reader controller pcb and the adf controller. Still same problem. It will do 20-30 duplex copies fine, but if you do 40, it throws the e202-0002 code upon the last sheet exiting the feeder.
        • charm5496
          • 2387
          did you try the interface PCB? FM2-3624-000
          I would also check your wiring to make sure nothing is pinched to the frame or a wire tie being too tight.
          • teckat
            • 16083
            check that the Glass Holder Assembly moves freely with no binding. Check the tie wraps on the connector for the M6 motor.
            Loosen the two screws and apply pressure to the clamp making sure the belt teeth are seated in the clamp. Tighten the screws and test for CIS homing and white plate reading. With the DADF front cover removed you can watch the CIS move from home to reading position by powering the IR5075 off and on .
            • charm5496
              • 2387
              he has the 6570 teckat which is the old style scanner.
              • teckat
                • 16083
                thanks,
                out with the old in with the new
                • repeatcopiers
                  • Sep 2008
                  • 591
                  Yes, we did repl the interface pcb as well. Will check wiring next.
                  • charm5496
                    • 2387
                    I remember fighting this same code several years ago and i ended up replacing the wiring harness in the DADF and both the flat ribbon cables under the glass after swapping boards and getting no where with it.
                    • charm5496
                      • 2387
                      Originally posted by teckat
                      thanks,
                      I have so much old information up in my head I find myself double checking what I am thinking all the time!!!
                      • teckat
                        • 16083
                        think about this issue for a moment>>
                        first the poster said>
                        after 50 two-sided, copies the last sheet would exit & the error pops up
                        then poster says after replacing parts >
                        after 40 two-sided,copies the last sheet would exit & the error pops up
                        so network two-sided prints OK!=this would eliminate all those parts replaced-
                        one sided copies & prints from DF are OK !=this would eliminate DF and Reader
                        and 20 to 30 two-sided prints work fine
                        Ok we have replaced the hp sensor, motor and board. We also replaced the reader controller pcb and the adf controller interface pcb as well.
                        Communication break down between DF>Reader>Printer
                        • gensys
                          • Jan 2011
                          • 323
                          It is a sensor control or conducting connected with a sensor control >> check wiring
                          Motors and PCB
                          seldom fail....
                          • tenatal
                            • Aug 2011
                            • 35
                            hi guy, just check the plastic plate on scanner for any damage
                            when the scanner return on its position after original finish then due to damage plate the hp sensor can't able to read scanner home position.
