ir 330s with E530
  • stupidmachines
    • Dec 2007
    • 14
    ir 330s with E530
    Hi folks, I was out at a customers for a printer and they did the old "while your here". I have nothing on this machine in the way of reference material. Anyone have some info they can share?
  • Luther
    • May 2006
    • 682
    This is a finisher error more to the point its the stapler guide is out of position, hope this helps
      • 23010
      Faulty rear jogger plate motor or faulty rear jogger plate home position sensor. If this is a finisher-E1 you may have a loose ground screw on the finisher controller.
