Canon IRC 3220 power supply
  • hknwbec
    • 214
    As the panel of irc 3220 is no display and only has the power light is on. sometine it is always related to the power supply unit. could you let me have some informations on how to repair the power suppy unit. Is it related to DC controller.
  • charm5496
    • 2387
    Re: Canon IRC 3220 power supply
    more than likely this is a main controller, RAM, boot rom issue.
    • its_just_a_copier
      • May 2011
      • 132
      I agree, its a very common issue on this model. Sometimes reseating all of your Main Controller sub PCB's and chips can get you running, or just replace the above mentioned parts one by one.
      • Hopper
        • Jul 2008
        • 173
        I had one just like that. On the rear of the machine there is a connector board.
        It is dead center of everything. With the back cover taken off you could draw an imaginary line from top left to bottom right, Top right to bottom left and these lines would cross right where this board is. Cold solder joints! Remove and remelt contacts.
        Hopper
        • teckat
          • 16083
          Did you check your wall voltage-neutral and ground ? neutral to hot ? hot to ground ?
          Control Panel Display is Dark
          First try re-seating the Dimms,the Boot Rom and the Option Boards(Network/Resolution/Open interface).If the problem still exists replace the Power Distribution PCB.(FG6-9676-000)
          Check the connection between the Sub-Main Controller (J1303) and the Main Controller (J1209) to see if they are seated correctly. When installing the Sub-Main Controller press the connectors together
          • hknwbec
            • 214
            Yes, the Power Distribution PCB has problem, may be poor contact, Is Ok Now
            • teckat
              • 16083
              good find>>>>>>>>>>>>
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5015
