IR 330 E 004
  • Hopper
    • Jul 2008
    • 173
    [Error Code] IR 330 E 004
    Canon IR 330 high milage and has been on the same outlet for years.
    Show up reset code. Machine running.
    Next day E 004 Show up, remove fuser, cleaned sensors. Reset machine copier running.
    two Days latter. Same code, switched out entire fuser with known running copier. Machine running.
    Next day- sames code. Came prepared with a matched (1)SSR and (1)relay. Switched out components. Machine running just fine.
    Next day E-004, same code. Switched out DC controller (sub DC controller on back of copier). Reset code, machine running on Friday.
    That brings us up to today! Same code E 004. Reset code, machine running! What the heck next???
    I do not think the outlet is bad. I did unplug it from a eyecon surge suppressor three calls ago.
    TIA
    Hopper
  • jake24482
    • Apr 2011
    • 116
    Re: IR 330 E 004
    how about composite power supply
    • jake24482
      • Apr 2011
      • 116
      Re: IR 330 E 004
      before power supply replace image processor pcb
      • charm5496
        • 2387
        Re: IR 330 E 004
        any construction going on in the area where this machine is at? Noise on the AC line can cause and E004 code.
        • Simons
          • Jun 2008
          • 490
          Re: IR 330 E 004
          I agree with Charm. However if that all checks out then the last thing on the list in chapter four is the Image processor! seen one do a c-kill . That was funny.
          • teckat
            • 16083
            Re: IR 330 E 004
            Did u test or monitor the outlet voltage ??
            neutral to ground ?
            neutral to hot ?
            hot to ground ?
