errcr code clear canon ir6000/ir5000/ir3300
  • kim moo young
    [Error Code] errcr code clear canon ir6000/ir5000/ir3300
    1. additional functions (push)
    2. function (choice)
    3. error (choice)
    4. error code choice (wait)
    5. reset (push)
    6. right power supply off
    7. right power supply on
  • canonjh
    • 39
    Re: errcr code clear canon ir6000/ir5000/ir3300
    안녕하세요?
    한국분인것 같은데요 무슨내용인지...
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      3. error (choice)
      5. reset (push)
      You can't find function in additional functions.Need to go in service mode.
      • lef2wander
        press additional functions release press 28 at same time release press additional functions again u should now see service mode if not press c/a key
        start over
        in service mode press copier function clear err ok then turn off on main power some error codes will cause copier to power of in 60 90 secs so be quick
        • neiloucha
          copeur CANON IR3300 error E000051-0000
          • teckat
            • 16083
            Re: copeur CANON IR3300 error E000051-0000
            This code refers to a problem with the Horizontal Home Position Sensor, or the Horizontal Registration Motor M3.
            check for broken gear on the Horizontal Registration Motor.
            Gear- 14T / 56T-FS7-0750-000
            M3 Motor - FK2-0144-000
            check contact pin at intermediate connector J3040-2. This is the signal line for M3, the horizontal registration motor. Reform the contact pin if bent >to the proper position.
            E051-0000- At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
            Main Cause- The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
            1. Connector
            Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
            a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
            b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
            NO: Connect the connectors.
            2. Sensor lever (damage and interference),
            Sensor
            Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
            YES:
            a. The horizontal registration assembly is out of place because of damage to the sensor lever. Replace the sensor lever.
            b. The horizontal registration assembly malfunctions because of the presence of foreign matter. Remove the foreign matter.
            c. The sensor is faulty and cannot detect home position. Replace the sensor.
            3. Horizontal registration motor, DC controller PCB
            Is the horizontal registration motor control signal generated by the DC controller PCB?
            J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
            YES: The horizontal registration motor is faulty.
            Replace the motor.
            NO: Replace the DC controller PCB.
            • neiloucha
              [ATTACH=CONFIG]14500[/ATTACH]
              [ATTACH=CONFIG]14501[/ATTACH]
              1. Connector
              Sensor
              YES:
              Replace the motor.
              THX FOR HELP
              and another error machine on my ir5000dx (E000602-0003) if you can help me and thx a lote
              nourddine_troudi@hotmail.com
              • teckat
                • 16083
                E602-0003 error code.
                At times, a sector error occurs when the power is turned off while data is being written to the HDD. This will indicate 'E602-0003' and prevent the machine from entering service mode.
                first try a HD-Check-
                To execute this mode, hold down the '1' and '9' keys on the keypad for approximately 6-8 seconds. A flashing block will show in the top left corner of the LCD.
                Normally, 'HD-Check' lasts about 15-20 minutes, and ends if no fault is encountered or specific sectors have automatically been repaired bringing up DOWNLOAD MODE on the LCD.
                DO NOT STOP ONCE STARTED.
                In certain cases,"HD-Check" can take longer than 15-20 minutes and sometimes the machine can hang in this mode and will never complete.
                if it returns an error-u need to get a new Hard Drive> & re-load printer firmware using the Canon SST (Service Support Tool)
                • neiloucha
                  Hi,
                  Thank's a lot for your help .. so where can i find this new Hard Drive nourddine_troudi@hotmail.com
                  • teckat
                    • 16083
                    Hi,
                    search online for any of these> most are old #'s
                    the original Canon OEM part is------
                    Hitachi Deskstar
                    HDS728040PLAT20 = WM2-5222-020
                    any of these will work
                    HDWN 'FUJITSU MPC3032AT
                    HDWN 'FUJITSU MPD3043AT
                    HDWN 'FUJITSU MPE3064AT
                    HDWN 'FUJITSU MPF3102AT
                    HDWN 'FUJITSU MHK2060AT
                    HDWN 'FUJITSU MPG3102AT E
                    HDWN 'FUJITSU MHN2300AT
                    HDWN 'FUJITSU MHT2020AT MF
                    HDWN 'FUJITSU MHV2040AH
                    HDWN 'QUANTUM FIREBALL CX6.4A
                    HDWN 'QUANTUM FIREBALLlct10 05
                    HDWN 'QUANTUM FIREBALLlct08 04
                    HDWN 'QUANTUM FIREBALLlct15 07
                    HDWN 'QUANTUM FIREBALLlct20 10
                    HDWN 'TOSHIBA MK6014MAP
                    HDWN 'TOSHIBA MK6015MAP
                    HDWN 'TOSHIBA MK1016GAP
                    HDWN 'TOSHIBA MK6017MAP
                    HDWN 'TOSHIBA MK2023GAS
                    HDWN 'TOSHIBA MK4032GAX
                    HDWN 'IBM-DJSA-205
                    HDWN 'IBM-DARA-206000
                    HDWN 'IBM-DJSA-210
                    HDWN 'ST34311A
                    HDWN 'ST34313A
                    HDWN 'ST310211A
                    HDWN 'ST340015A
                    HDWN 'ST92011A
                    HDWN 'ST340014A
                    HDWN 'ST940210A
                    HDWN 'IC25N006ATDA04-0
                    HDWN 'IC25N010ATDA04-0
                    HDWN 'IC35L040AVER07-0
                    HDWN 'IC35L020AVER07-0
                    HDWN 'IC25N010ATCS04-0
                    HDWN 'IC25N020ATMR04-0
                    HDWN 'Maxtor 2B020H1
                    HDWN 'MAXTOR 4K020H1
                    HDWN 'Maxtor 2F030J0
                    HDWN 'Maxtor 2F040L0
                    HDWN 'WDC WD400BB-22HEA0
                    HDWN 'WDC WD400BB-22JHC0
                    HDWN 'WDC WD300AB-00BVA0
                    HDWN 'WDC WD800BB-22JHC0
                    HDWN 'HDS722540VLAT20
                    HDWN 'HDS728040PLAT20
                    HDWN 'SAMSUNG SV2001H
                    HDWN 'SAMSUNG SV0211H
                    HDWN 'SAMSUNG SV0221N
                    HDWN 'SAMSUNG SV0411N
                    HDWN 'SAMSUNG SP0411N
                    HDWN 'ExcelStor Technology J120
                    HDWN 'ExcelStor Technology J64
                    HDWN 'Hitachi HTS541640J9AT00
                    • neiloucha
                      Hitachi Deskstar
                      HDWN 'IBM-DJSA-205
                      HDWN 'IBM-DJSA-210
                      HDWN 'ST34311A
                      HDWN 'ST34313A
                      HDWN 'ST310211A
                      HDWN 'ST340015A
                      HDWN 'ST92011A
                      HDWN 'ST340014A
                      HDWN 'ST940210A
                      No, you don't handerstand me ! I have the HDD' and I want the software and the the Canon SST sorry for the inconvenience :/
                      • zoraldinho
                        • Mar 2008
                        • 5015
                        Need service support tool and firmware and a lot of knowledge.
