cleaning roller for web
  • daveh213
    • Jul 2025
    [Misc] cleaning roller for web
    IS there any experience with the roller flaring and causing jamming in fuser?
  • costd
    • Jan 2008
    • 409
    Re: cleaning roller for web
    Might help if you mention the model.
    • daveh213
      IR8500 is the model
      • charm5496
        • 2387
        are the bearings, bushings and rollers in good shape? Usually when the bearings lock up and start eating the lower shaft you get all kinds of fuser jams
        • daveh213
          What I mean is there any problem associated with the cleaning roller that presses the web against the upper roller, flaring at the ends causing problems.
          • vigour
            • Aug 2010
            • 1038
            She understood your question.
            She is just giving you a better place to look for your jamming.
            I've not seen that before, but it is a copier, stranger things have happened.
            Only one way to know. Change it and see what happens.
            • charm5496
              • 2387
              who are you calling a she?
              • charm5496
                • 2387
                When you say flare does it flare out or is it compressed???? If it is flaring our and keeping
                the web from touching the roller then guess what...no silicon oil is being applied!!!! and then it will cause jams since the toner will stick to the roller.
                • daveh213
                  Thanks for all the help. I will change it.
                  • zoraldinho
                    teacher-guide-expert-guru
                    • Mar 2008
                    • 5007
                    • charm5496
                      • 2387
                      Originally posted by zoraldinho
                      [ATTACH=CONFIG]10841[/ATTACH]
                      Thanks Z!!!! LOL
                      • vigour
                        • Aug 2010
                        • 1038
                        sorry , it was late at night, too tired
