i had reinstall new hd of printer board (canon ir600)and see must to do like this
EFI PRINT BOARD SOFTWARE INSTALLATION PC REQUIREMENTS
2. Print FONT list
3. Power down machine.
NETWORK PRINTER BOARD F1 SOFTWARE INSTALLATION
1. Connect parallel cable to the PC and the printer board.
2. Power up the PC.
3. Go to the DOS prompt.
4. Locate the software directory.
5. If updating the BOOT ROM then, GO TO STEP 6
6. On the PC type "COPY (FILE NAME.ROM) LPT1 /B"
8. Go into "Setup" on the printer board.
9. Select "UPGRADE FLASH" on the printer board.
10. Now on the PC, press " ENTER".
11. Wait for the download to complete.
12. When done installing the software, go to step 37.
13. ON PC TYPE "COPY (FILE NAME.UM) LPT1 /B"
15. Go into "SETUP"
16. Select "FORMAT DISK" and then press OK
17. Select " FORMAT OPTION" and then press OK.
19. Select "INSTALL SOFTWARE"
20. Then press "YES" , then press "OK".
21. On the laptop press "ENTER".
22. The data transfer then begins and checks the reading in (percent %) increments.
23. When data transfer is complete press "OK".
24. Then select "START SYSTEM" then press OK.
25. Go into setup and select "RUN SETUP"
26. Configure the printer board with the information from the configuration sheet from "MACHINE PREPARATION, STEP 1".
27. If complete with the installation of the system software, "then go to STEP 37".
30. Go to setup
31. Select "INSTALL SOFTWARE"
32. SELECT "YES" and on the laptop computer press "ENTER".
33. Data transfer will be indicated in "CHECK % READING IS INCREMENTING"
34. When data tranfer is complete then press "OK"
35. Select "START SYSTEM", and then press "OK"
36. If install of system software is complete then go to " STEP 37"
38. Remove the parallel cable from the computer and the printer board
39. If system software and postscript upgrade was installed and completed then , "CONFIGURE PRINTER BOARD",if not then go to end.
40. Print out font list and compare to the first list before the install occurred
41. Download the missing fonts if necessary. end
the promblem how can i find the file for (filename.um)and (filename.psu) if anyone know please tell me thank
taejing@hotmail.com
- W95 +
- CD-ROM
- 150 MB +
- Parallel port set to ECP
- BI-DIRECTIONAL CABLE IEEE 1284
2. Print FONT list
2. Power up the PC.
- IF UPDATING SYSTEM SOFTWARE, GO TO STEP 12
- IF UPDATING TO POSTSCRIPT OPTION, GO TO STEP 23
- "DO NOT PRESS ENTER"
- UPDATING SYSTEM SOFTWARE
DO NOT PRESS ENTER
14. REBOOT the printer board 15. Go into "SETUP"
- Hard drive FORMAT OPTIONS
USE "STANDARD "FORMAT" FOR REINSTALLING SYSTEM SOFTWARE
USE "FULL FORMAT" TO CORRECT ANY BAD SECTORS PROBLEM. THIS WILL TAKE APPROXIMATELY 30 TO 60 MIN.
USE "FULL & VERIFY FORMAT" TO DIAGNOSE PROBLEMS.
- PERFORMING POSTSCRIPT UPGRADE
- DO NOT PRESS ENTER
30. Go to setup
- COMPLETING SOFTWARE INSTALLATION PROCEDURE
taejing@hotmail.com
