how to find xxx.um file
  • taejing
    i had reinstall new hd of printer board (canon ir600)and see must to do like this
    EFI PRINT BOARD SOFTWARE INSTALLATION PC REQUIREMENTS
    • W95 +
    • CD-ROM
    • 150 MB +
    • Parallel port set to ECP
    • BI-DIRECTIONAL CABLE IEEE 1284
    MACHINE PREPARATION1. Print Configuration Page
    2. Print FONT list
    3. Power down machine.
    NETWORK PRINTER BOARD F1 SOFTWARE INSTALLATION
    1. Connect parallel cable to the PC and the printer board.
    2. Power up the PC.
    3. Go to the DOS prompt.
    4. Locate the software directory.
    5. If updating the BOOT ROM then, GO TO STEP 6
    • IF UPDATING SYSTEM SOFTWARE, GO TO STEP 12
    • IF UPDATING TO POSTSCRIPT OPTION, GO TO STEP 23
    UPDATING BOOT ROM
    6. On the PC type "COPY (FILE NAME.ROM) LPT1 /B"
    • "DO NOT PRESS ENTER"
    7. REBOOT the printer board.
    8. Go into "Setup" on the printer board.
    9. Select "UPGRADE FLASH" on the printer board.
    10. Now on the PC, press " ENTER".
    11. Wait for the download to complete.
    12. When done installing the software, go to step 37.
    • UPDATING SYSTEM SOFTWARE
    13. ON PC TYPE "COPY (FILE NAME.UM) LPT1 /B"
    DO NOT PRESS ENTER
    14. REBOOT the printer board
    15. Go into "SETUP"
    16. Select "FORMAT DISK" and then press OK
    17. Select " FORMAT OPTION" and then press OK.
    • Hard drive FORMAT OPTIONS
      USE "STANDARD "FORMAT" FOR REINSTALLING SYSTEM SOFTWARE
      USE "FULL FORMAT" TO CORRECT ANY BAD SECTORS PROBLEM. THIS WILL TAKE APPROXIMATELY 30 TO 60 MIN.
      USE "FULL & VERIFY FORMAT" TO DIAGNOSE PROBLEMS.
    18. When the format is complete then press "OK".
    19. Select "INSTALL SOFTWARE"
    20. Then press "YES" , then press "OK".
    21. On the laptop press "ENTER".
    22. The data transfer then begins and checks the reading in (percent %) increments.
    23. When data transfer is complete press "OK".
    24. Then select "START SYSTEM" then press OK.
    25. Go into setup and select "RUN SETUP"
    26. Configure the printer board with the information from the configuration sheet from "MACHINE PREPARATION, STEP 1".
    27. If complete with the installation of the system software, "then go to STEP 37".
    • PERFORMING POSTSCRIPT UPGRADE
    28. On the laptop type "COPY (FILE NAME.PSU) LPT1 /B"
    • DO NOT PRESS ENTER
    29. REBOOT the Print board
    30. Go to setup
    31. Select "INSTALL SOFTWARE"
    32. SELECT "YES" and on the laptop computer press "ENTER".
    33. Data transfer will be indicated in "CHECK % READING IS INCREMENTING"
    34. When data tranfer is complete then press "OK"
    35. Select "START SYSTEM", and then press "OK"
    36. If install of system software is complete then go to " STEP 37"
    • COMPLETING SOFTWARE INSTALLATION PROCEDURE
    37. Power down the laptop computer.
    38. Remove the parallel cable from the computer and the printer board
    39. If system software and postscript upgrade was installed and completed then , "CONFIGURE PRINTER BOARD",if not then go to end.
    40. Print out font list and compare to the first list before the install occurred
    41. Download the missing fonts if necessary. end
    the promblem how can i find the file for (filename.um)and (filename.psu) if anyone know please tell me thank
    taejing@hotmail.com
  • yourownfree
    • Dec 2007
    • 474
    the file um is 70 mb and the downloader program pdl downloader is 3.1 mb. I have those if you don't already have from another.
    I can possibly put them somewhere for you to download. I cant send 70 mb through the email-too big. I will email you the downloader program. also as i remember there are two files for the 300/400 but only need one for the ir600
    i will send you the link to download the um file from my file storage site. Thats all you need. There is only one file for the 600. psu was for the 330/400 postscript file.
    • taejing
      thank you for your help
      taejing
