E021-0320 iR Advance C2030H
  • huanphung
    • Aug 2025
    [Error Code] E021-0320 iR Advance C2030H
    Hi everyone.
    I had a problem with ir Advance C2030H.
    Firstly, the machine had jam and show a jam code 0cf1, after i remove paper jam and close right door, the machine had continue jam with the same jam code 0cf1.
    Then I turn off the machine and turn it on, the machine had error with error code "E021-0320".
    I already tried many times as in service manual guide, but i don't get result.
    Anyone has the same problem ?..We can discuss together..
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: E021-0320 iR Advance C2030H
    Check if you have preasure lever of the BK drum pushed all the way in.Replace the BK drum.
    • huanphung
      Thanks zoraldinho !
      I already removed Bk drum and installed in many times, i also removed Black Hopper then installed again, but the error is the same, maybe I had to replace new Bk drum.
      • Copierdocisleofman
        Senior Technician
        • Aug 2009
        • 86
        Try COPIER > FUNCTION > INSTALL> Stir4 . This will stir the developers as if the machine is new. might be worth a try.
