CANON IMAGEPRESS C1
  • worthy67
    • Mar 2010
    • 24
    CANON IMAGEPRESS C1
    Hi wonder if anyone can help
    got an imagepress c1 that keeps just switching off and rebooting of its own accord.
    The green power led stays lit on the controll panel and the main power switch is still on.
    No error codes.
    Replace ac and dc p.s.u the pkit and d kit also itb assy .
    Nothing on canon dealernet or simm portal.
    mark
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: CANON IMAGEPRESS C1
    Hi worthy
    Did you try to replace DIMM, DDR SDRAM FK2-0755-000
    Check cable hard disc power supply
    • worthy67
      • Mar 2010
      • 24
      Originally posted by zoraldinho
      Hi worthyDid you try to replace DIMM, DDR SDRAM FK2-0755-000Check cable hard disc power supply
      Hi I haven't tried this so will give it a go Thanks very much for your help
      • teckat
        • 16083
        No error codes.
        mark
        to add a point>'
        Check your power outlets/ had a few customers with power drops over 10/15% while printing
        had same symptoms you describe
        imagePRESS C1
        Main unit has 2 different plugs
        1) 20A, For Main unit.
        2) 15A, For Buffer Pass which is included in a main unit and attached ACC’s (*w/o imagePRESS Server-Q1/T1, Paper Deck AA1)
        -iPR Server Q1/T1 and Paper Deck AA1 each have their own plugs.
        click on pic for better view
        • its_just_a_copier
          • May 2011
          • 132
          How about a shorted thermistor?
          • worthy67
            • Mar 2010
            • 24
            Thanks for your help guys some good points I will check these ideas out.
