Canon ir4570/3570/2270 etc. Jammig in right door
  • mrfixit51
    Lead Service Technician
    • 1975
    mrfixit51's 2 cents worth
    Originally posted by Karsten
    Also, the foam strip is old news, it was a temporary solution. Instead replace the lower right door and lower right inner door, Part# FM3-1296 and FM3-1297.
    Amen to that Karsten,
    Using the foam caused as many problems for me as the little pads falling off the door did. Go right for the update parts,, you will not be sorry! As Screwtape mentioned, you have to pull cassette 1 feed assembly out of the copier to replace the grey roller. You can replace cassette 2 roller while you have #1 feed assembly out of the machine, without removing that assembly. Be sure to lube the 1-ways while you have the gear off the shaft!
    • mrsoul
      • 18
      you can replace this 2 modification parts to improve the paper flow FM3-1296 Right Lower Door ass'y and FM3-1297 Right Inner Door ass'y. I hv try is good
      • Oze
        Ricoh Fanboy
        • 1663
        I've done that mod on an iR3570 that was jamming all day every day and haven't been back to that machine for 2 months.
        AND...
        I'm sitting here with the parts in front of me to go out and mod another 3570:
        FM2-0132-000:Right Lower Inner Door Assembly
        FM3-1296-000:Right Lower Door Assembly
        FC5-0567-010:PICK-UP ASSY MOUNT,U PLATE
        FC5-0641-010:SENSOR COVER
        FB6-4852-000:VERTICAL PATH ROLLER
        Once that's done say goodbye to 0107/0201 jams
        • SCREWTAPE
          #19
          It seems like canon revised some the part # for these items.
          Right lower door ass'y FM2-0131-030, Used to be:FM3-1296-000
          Right Inner door ass'y FM2-0132-000, Used to be:FM3-1297-000
          Thanks oze for bringing the Right Inner door ass'y FM2-0132-000 to my attention. For a minute i thought you was posting an incorrect part #
          so, I had to checked it out and I notice that they revised both part #
          for the Right lower door ass'y and Right Inner door ass'y.
          • Oze
            Ricoh Fanboy
            • 1663
            #20
            No worries at all m8...
            I got lazy(see sidetracked by other jobs) and ended up turning their paper to landscape to keep them running til I do the mod tomorrow.
            • cweber0531
              • 71
              #21
              That assembly is not fun to remove. Thanks for your help guys.
              P.S. Any of you rebuild the fusers on this series? I have replaced a couple and thought about rebuilding but does not look easy, especially the fixing film.
              • Oze
                Ricoh Fanboy
                • 1663
                #22
                Once you've done the fuser rebuild a few times,it's like most fixing film related fusers,you can do it in your sleep.
                The only real tricky part is to make sure that you line the teeth up on the pressure release levers.
                Average time for a rebuild is around 45mins.
                • slr
                  • Dec 2008
                  • 3
                  #23
                  hi Oze
                  fuser sleeve used in 3570 is the same as 2200 or diffrent?
                  i tried to rebuild 3570 fuser with 2200 fuser sleeve but sleeve got damaged (cut in the center) with in few copies. tried in 3 units
                  advice on this topic is very usefull
                  • mjarbar
                    #24
                    Hello,
                    The sleeves are different, the iR22/3300 (FG6-6041-120(230V) and FG6-6039-000(120V)) have a few but slight differences to the xx70/30xx models:
                    FM2-0358-000 (120V) 3025/2270/2870
                    FM2-0359-000 (230V) 3025/2270/2870
                    FM2-1793-010 (120V) 3035/3045/3570/4570
                    FM2-1812-010 (230V) 3035/3045/3570/4570
                    Mainly the differences are in the materials used due to a change in the timings etc. of the 'on demand' way in which the fixing assy operates.
                    Oze is right when he says once you have done a few it becomes second nature, just allow a little time to do them and as he says make sure the teeth match up when you put it back together as they were when you take them apart (a perminant marker helps there), and most importantlly ensure the brass connector is screwed into place as it can come into contact with the rest of the fuser assy and cause it to short. If you are lucky it cause the electrics to trip and a new fuse req. for the plug other wise you are looking at all sorts of trouble
                    • Barcode
                      #25
                      iR-4570 intermittent jam
                      I know that posting has been going on for a while. But. Here is a recent solution I have just found for right door jams (especially intermittent ones) with sheets jammed everywhere before and into fusing unit. Are you getting copy folded into a Z? After removing fusing unit, try rotating by hand. If particularly stiff, there you are. Open fusing unit, remove that heat sleeve very carefully, cause it is so easy to shear, clean inside and ceramic unit as well with a dry cloth and put fresh new fusing (white) GREASE on the heat assembly. Get everything back together. Rotate gently to get that new grease spread.
                      Also check for the magnet that hold R. door. Mine was getting off. Door would not close properly. Try it.
                      • tongee
                        • Nov 2009
                        • 50
                        #26
                        Originally posted by Jmat77
                        I have three machines that jam intermitten in the right door verticle paper path. Can anyone tell me if there is a kit or a list of parts to modify or fix this door problem?
                        replaces roller FC5-1017-000
                        • zulufan1
                          • Oct 2009
                          • 45
                          #27
                          IKON Tech,s
                          As an Ikon Tech, We are using alot of Katun Parts, and We all just use the 29129 Film Only, For E-007 or CQ-Jamming issues. This film is compatable with the Ir2200-3300 and Ir2270-3570 series machines, and the newest series as well. The film just takes a couple more minutes to change than the assy, and is so much less expensive that We can stay within budget.
                          As long as we change the cleaning roller at the same time, and lube the inside of film, these seem to last just as long as the OEM assemblies.
                          When We were a Canon dealer, We only did the assemblies.
                          • tsunamisimbu
                            • Sep 2009
                            • 2
                            #28
                            wanted sst
                            hi friends i need canon ir3300 service support tool please give me in my mail id tsunamisimbu@gmail.com
                            • delosangeles
                              • May 2008
                              • 274
                              #29
                              Re: Canon ir4570/3570/2270 etc. Jammig in right door
                              Hello everyone, our company just placed a few of this IR 2270 on contract and they are now jamming at the right door but only from tray #1 could some one send us or post here any PDF's or pics of the this jamming problem. Thank you guys very much.
                              Trade like a tiger sleep like a baby
                              • danko72
                                • Jan 2012
                                • 13
                                #30
                                Re: 4570 jams
                                Originally posted by lkrsardis
                                kwazimoto is right. write me and i will send you some pdfs about the jam problem. it would help to have the jam codes.
                                Hello I'm writing in replay to you commentary. I have that problem. Can you help about it? I have an IR3570. Thanks
