ir 1024 MC JAMMING
  • tekkie
    • Mar 2011
    • 114
    [Jamming] ir 1024 MC JAMMING
    I have a basic ir 1024 mc that is jamming 3 or 4 times a day with 0208 codes i have tried a new fuser unit complete i have checked sensors on paper feed path it has new feed and sep rollers and modified springs in the cassette still jamming its a new mc only 4k on clock only been installed for a month any ideas
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: ir 1024 MC JAMMING
    3-4 times a day?One word. PAPER
    • teckat
      • 16083
      0208 occurs as the copy lead edge stops between the registration roller and the fixing assembly. The 0208 jam is listed as a stationary jam at the registration roller.
      Replace or Inspect the SL2 solenoid/on Paper Pick-Up Assembly
      Check the locking force of the Left Door Assembly/continuous copying/printing could have deformed the Left Cover Open/Close Lever
      installation position of the Compression Spring for lever is changed, and the number of Compression Springs has increased from 1 to 2
      the length of the Compression Spring, the shape of the Left Cover Open Close Lever and the
      Rear Fixing Guide have been changed.
      CLICK ON PICS for better View
      New-Left door Assembly FM2-9044-010
      New-Compression Spring (2) FU8-2277-000
      New-Left Cover Open/Close Lever FC7-2952-010
      New Rear Fixing Guide FC6-7455-010
      • robycyp
        I had the same problem and I resolved it by replacing the SW2.
