Cannon IRC 3200 copying with yellow mask
  • Progman
    • Aug 2025
    Hi All,
    I have a Canon IRC 3200 that prints a yellow mask when I print in color. I placed a balnk paper to see what would happen in colour mode but all i get is a yellow color printed out. If I print in balck and white the paper comes out fine. I tried swapping out the toner and drum unit for the yellow section but i still have the same results. Pleas e let me know what else i can try.
  • Caldo
    • 69
    Re: Cannon IRC 3200 copying with yellow mask
    Are you using geniune manufactured consumables? cos if not it might contribute to the problem.
    • teckat
      • 16083
      Originally posted by Progman
      Hi All,
      Turn off PASCAL in service mode. Run CCD AUTO ADJ. Turn PASCAL back on. Exit service mode and complete a FULL Autogradation.
      u copy off the glass with a blank sheet> hit the print key and background is covered in yellow ?
      what happens of full color network prints ????
      post a copy of your issue/
      Check to see if the Thrust Pin (FF6-2099-000 # 31) and Compression Spring (FS7-2826-000 #35) are making good contact with the Drum Grounding Plate.The spring can shift causing poor contact between the Drum Unit and Drum Unit Cover assembly.
      This can happen with any color
      • Progman
        All of the consumables are geniune manufactured. I would check the drum section and let you know my findings.
        I managed to get hold of a test sheet and this is the end result when i tried to make a copy from the scanner.
        • teckat
          • 16083
          Your DDI-S PCB or cable could be the problem.
          that is the top board /where the interface cable goes into
          check cable EXTERIOR connection position
          The part number for the DDI-S PCB is FG3-3136-000.
          • Progman
            Thank you ver much Teckcat your advice worked
            "Turn off PASCAL in service mode. Run CCD AUTO ADJ. Turn PASCAL back on. Exit service mode and complete a FULL Autogradation."
            I only have one issue now my 11 X 7 prints get stuck in the fixing feeder unit. I tried another unit i had from another printer but still get the same problems.
            Any ideas what I can look at to solve this?
            • teckat
              • 16083
              is this from one one tray location ?? what is jam code ??
              remove cassette tray/ take out paper/ shake/
              turn cassette upside down-look to see if white gear falls out/
              if so your paper width will not be recognized by sensor-
              make sure your 11x17 cassette is reading for that size on display panel
              • Progman
                Thsnks for all the help, I got the paper to work fine.
                • teckat
                  • 16083
                  Thanks, the SOLUTION WAS
                  • Progman
                    The White gear was not in place got it fixed and now there are no more paper Jams.
                    • teckat
                      • 16083
                      good, don't forget to look at the underside of the cassette where that post is located, inspect for crack, if u see one, the post will eventually break off, Canon has updated material,so they say- there is a fix with a metal stud, but who has time to follow Canon's useless instructions-
                      they break from customer changing paper size with full load of paper dropped in/ instead of adjusting slide > before paper is dropped in-
