imagePressC7000VP-Starter / Toner Spills from the Developer Assemblies (Revised)
  • teckat
    • 16083
    [Misc] imagePressC7000VP-Starter / Toner Spills from the Developer Assemblies (Revised)
    imagePressC7000VP-Starter / Toner Spills from the Developer Assemblies (Revised) Publication has been revised to include detailed diagrams showing the location of the imagePRESS C7000VP Series cooling and exhaust fans
    SEE pdf>>>TP11-1.pdf
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: imagePressC7000VP-Starter / Toner Spills from the Developer Assemblies (Revised)
    Every two weeks must supply a new starter on ip c 6000.
    • its_just_a_copier
      • May 2011
      • 132
      Have you guys ever heard of a toner clumping problem in Yellow Only? I've replaced the developing unit several times along with yellow hopper, subhopper, pipe, Drum, corona, transfer roller, etc.... this problem comes back within a few days.
      I've heard it could be related to the various cooling fans and I'm pursuing that route now, just wondering if it could be related to installing the new IPC7010 versions of firmware like v82 or v87 ?
      Canon says its compatible with the old IPC7000's, but could this be the problem?
      • teckat
        • 16083
        Did u read the Tech Pub above / it deals with Fans-http://www.copytechnet.com/forums/at...sed-tp11-1.pdf
        FM113 Process unit cooling fan (Y)
        FM114 Process unit exhausting fan (Y)
        FM160 Process unit front side cooling fan (Y)
        FM161 Process unit rear side cooling fan(Y)
        • its_just_a_copier
          • May 2011
          • 132
          yep thats what I'm checkin out now, just curious about the firmware.
          I know Canon has recognized this problem because they beefed up the fans with the IPC7010...
