irc adv 2020h
  • eurokris
    • 120
    irc adv 2020h
    hi greeting to all
    irc adv 2020h came out code E020 -0360.already check hopper unit .still same.pls advice me
    thanks
  • richd
    • Aug 2009
    • 49
    If I remember, you have to update the fw, this allows you to manually add toner to the hopper, there is a bulletin released for this, sorry can't be more specific.
    • teckat
      • 16083
      Re: irc adv 2020h
      Originally posted by eurokris
      hi greeting to all
      thanks
      imageRUNNER Advance C2020 / C2030
      Measure to prevent "E020-0xB1" and "E020-0x60" that occur due to the toner level-detection error:
      There is a case where a large amount of toner electrostatically adheres to the toner level detection sensor at the toner buffer, consequently detecting the presence of toner erroneously. If the device is used continuously in this situation, toner is not supplied to
      the P-unit developing assembly and then the T/D ratio decreases, consequently causing an "E020-0xB1" or "E020-0x60."
      Therefore, new service mode items have been added so that the toner can be supplied to the toner buffer after the sensor face is cleaned.
      Service Mode (Lv1):
      >COPIER >FUNCTION >INSTALL >SPLY-H-Y
      >COPIER >FUNCTION >INSTALL >SPLY-H-M
      >COPIER >FUNCTION >INSTALL >SPLY-H-C
      >COPIER >FUNCTION >INSTALL >SPLY-H-K
      *In order to use these service mode items, the combination with MN-CONT v20.xx
      (next version) or later is required.
      • Zoollanderhu
        • Aug 2010
        • 76
        Re: irc adv 2020h
        Service Mode (Lv1):
        Have you already tried the new hopper replacement? I've got the same problem and saw the bulletin about the error code, so asked for a new hopper in a flashreport. I 'm just curious about how does it work the new hopper. Is it better? will it stop the problem? have you got experiences about it?
