Hello everyone,
i have a recently trucked in ir7105 that is skewing image (type 1 test print), skew 1/16th inch top to bottom, replaced worn reg roller upper and lower, replaced reg tension springs and brakes, as well as both clutches. forced a jam at trans/reg area to verify paper is skewed not image, so I taken reg assembly out of equation via swapping entire fix/feeder frame ass'y from good machine. still Skewed. Any ideas?
