Ir c4080i
  • jose1020
    • 41
    Ir c4080i
    Color copies and prints blurry, black copies ok canon Ir c4080i any idea why is that?
  • londonboy
    • Jul 2011
    • 10
    Re: Ir c4080i
    Replace the complete itb assy, if you clean the inside of the belt and rollers it will run for a bit, but it will go blurry again
    • londonboy
      • Jul 2011
      • 10
      Re: Ir c4080i
      Sorry forgot to say it is the itb slipping!.
      • vigour
        • Aug 2010
        • 1038
        Re: Ir c4080i
        search the forum
        there are many posts about this
        at least one a week 3200. 5180
        • ESA
          Re: Ir c4080i
          When you say blurry are you saying all colours looked shifted? When you run a full calibration from Addition Functions are the colour lined up correctly looking down the page veritcally? It can be many things. There is a number of posts for sure. Your ITB can be slipping, Reg sensors can be dirty. Post a photo.
          • jose1020
            • 41
            Re: Ir c4080i
            • jose1020
              • 41
              Re: Ir c4080i
              Yea all colours looked shifted
              • ESA
                Re: Ir c4080i
                Yup. Pull out ITB and clean belt and rollers. Make sure rollers are turning freely and a bearing isn't seized. Likely you'll have to replace ITB belt or exchange with a known good machine to verify. However it is still likely your belt slipping due to nature stretch. Try cleaning assembly first. Good Luck
                • jose1020
                  • 41
                  Re: Ir c4080i
                  Thank you very much. I will try that
                  • ikon01
                    • Apr 2011
                    • 53
                    Re: Ir c4080i
                    i've had this plenty of times.your colour reg is way out.it's likely your itb is over life,if your gonna strip and clean the assy it's worth replacing the belt.if this doesn't cure it you may need to clear the dc con too,but consult your manual first.you will need to print a d or p print to re input the values..
                    • developer dumper
                      • Oct 2008
                      • 21
                      Re: Ir c4080i
                      be sure to replace the itb cleaning assy with the new itb and powder the belt well. I've had many to the cleaning blades flip.
                      • teckat
                        • 16083
                        Re: Ir c4080i
                        Since when do u put Powder on the ITB BELT
                        I have never seen a cleaning blade flip on this model/ worked on hundreds of these models
                        • mrfixit51
                          Lead Service Technician
                          • Oct 2008
                          • 1975
                          Re: Ir c4080i
                          I have had the blade flip issue on an iRC3380,, the blade flip would actually stall out the belt. Never had one on the 5185 family do this though...
                          • zoraldinho
                            teacher-guide-expert-guru
                            • Mar 2008
                            • 5015
                            Re: Ir c4080i
                            First,need to check life time counter in service mode,then you can talk about servicing or replacing parts.
                            • ikon01
                              • Apr 2011
                              • 53
                              Re: Ir c4080i
                              good point but i've seen the belts on these stretched as low as 60% life..and true gents i've never had a blade flip on these either..
