Canon Fax Guru needed
  • Herrmann
    • Jan 2006
    • 792
    [Error Code] Canon Fax Guru needed
    Problem:
    At one of our Customers, there is a Canon IRC1021 with Fax Option installed which works very well except of one Connection from Canada. TX is ok, RX times out with a ##106 Error shown which points to an Echo Problem.
    Things, i have done so far:
    Update the Firmware to the latest and greatest
    Country Settings to "Other" , to open the Tolerance Window as far as possible
    Reduced Modem Speed to 14400
    #1 SSSW-SW03 Bit 7 set to "1" , this will send a 1080 HZ Tone before sending CED to activate the echo supression
    #1 SSSW-SW04 Bit 3 and 4 to "1" to enlarge the Time Window after CFR
    Still no Joy
    Now i'm sitting here, scratching my head and running out of Ideas
    Somewhere out there, who can enlighten me?
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • 22999
    Re: Canon Fax Guru needed
    It sounds to me like a line problem at the other end. The best you can hope for is cooperation by the transmitter to work with their telephone provider. A simple test would be to insert the AT&T prefix 10288 before the dialed number to confirm that it's the long distance provider.
    IMHO you've done everything possible from the receivers end. =^..^=
    • Herrmann
      • Jan 2006
      • 792
      Does this work in Canada as well?
        • 22999
        Oh. I never thought of that.
        Can any of you Canadians answer that?
        • CDVMike
          • Jul 2008
          • 33
          Turn off the Error Correction Mode and see if that helps. ECM can slow down bad connections.
