canon mf 4450
  • George_H
    • Jul 2025
    canon mf 4450
    Dear All;
    I have a problem in many canon mf 4450 multifunctions.
    the problem is that machine unable to send or receive faxes!!
    when i open the phone line to send a fax, i hear the tone voice, i hit the fax number that i want to send to, but nothing changes, i keep hearing the same continuous tone voice and there is no way to send the fax, all i get is the continuous tone voice.
    have anyone experienced this issue before and can help me. i wish.
    Regards to you All.
  • teckat
    • 16083
    Re: canon mf 4450
    Originally posted by George_H
    Dear All;
    Regards to you All.
    Ensure that the telephone line is not receiving interference from nearby devices-----microwave-refrig-fire dept nearby
    Print an Activity Report and check for an error.
    • George_H
      Re: canon mf 4450
      Dear sir,
      Kindly advice howto print the Activity Report.
      Thanx
      • teckat
        • 16083
        Re: canon mf 4450
        Dear sir,
        Thanx
        check link here below-HOW to print reports >>https://www.canon-europe.com/Support...=tcm:13-790891
        support MF4450=https://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/Laser/LaserBase_MF_series/i-SENSYS_MF4450.aspx?faqtcmuri=tcm:13-790905&page=1&type=faq
        do u have your product CD
        • George_H
          Re: canon mf 4450
          Dear Sir, i can assure to you that the telephone line is very clear ( no interference with other electrical devices...etc).
          the activity report lists many Negative comunications Results with the description ( AUTO TX G3 -NG 00'00 #995).
          please note that when i open the phone line to send the fax, i hear the voice tone, then when i hit the first number of the destination fax number, the voice tone gets louder and keeps toning toooooooooooot forever, and the machine does not respond to any button i hit after that.
          i have to turn the machine off and on again to stop that toning from going off.
          unfortunately i do not have the service manual for this machine.
          any suggestion to solve this issue
          Thanks.
          • teckat
            • 16083
            Re: canon mf 4450
            Thanks.
            when did this issue start ? where u or another tech working on printer ??
            have u run a Line test in service mode ??
            #995 [ TX / RX ] Job Canceled
            Cause
            -Memory communication reservation jobs were cleared, someone
            deleted the job
            Remedy
            -Repeat the procedure (job) if necessary
            did u have the line tested ??
            Fax machines communicate over single line phone networks where the 'Ring' and 'Tip' voltages are always located across the two center terminals. Line voltages are checked accordingly:
            on-hook voltage (phone is hung up)
            --set the volt meter to 200 vdc
            --should read within the 48vdc ~ 52vdc range
            off-hook voltage (phone is off-hook and dial tone is generated)
            --should read within the 8 vdc ~ 12 vdc range
            ringing voltage (incoming call)
            --set the volt meter to 200 vac
            --should read within the 75 vac ~ 105 vac range
            RJ11-C Modular jack: Testing phone line voltages can be difficult if not impossible at times unless you can establish a really good connection to the phone line.
            The RJ11-C box can be used to establish a good connection.
            --RJ11-C box with two female connectors (remove the cover and test with your meter across the red and green terminals). An additional phone cable is required.
            --RJ11-C box with one male and one female connector; remove the cover and test with your meter across the red and green terminals).
            • George_H
              Re: canon mf 4450
              Dear Teckat,
              i have just checked the phone line and the voltages on it. All voltages ( on-hook, off hook and voltage during ringing on ) are CORRECT.
              please let me focus again on the state that the machine goes through:
              "when i hang on to send the fax, i hear the voice tone, then when i hit the first botton number of the destination fax number, the voice tone gets louder and keeps toning toooooooooooot forever, and the machine does not respond to any button i hit after that.
              i have to turn the machine off and on again to stop that toning from going off."
              i Deeply appreciate any other suggestion from you.
              Regards.
              • teckat
                • 16083
                Re: canon mf 4450
                are u using VOIP
                • George_H
                  Re: canon mf 4450
                  NO Sir.
                    • 23003
                    Re: canon mf 4450
                    What happens when you plug in a plain old analog telephone? Can you dial now? Do you need a prefix? Is the phone line plugged into the handset jack? =^..^=
                    • George_H
                      Re: canon mf 4450
                      Same issue when i plug in a plain old analog telephone, still can not dial. i just get a continuous tone.
                      ofcourse the phone line is not plugged into the handset jack.
                        • 23003
                        Re: canon mf 4450
                        Then it's a problem with the phone line, not the fax.
                        Why "of course"? The same RJ11 jack is used for both the line and the handset. It's a very common mistake to choose the wrong one. =^..^=
                        • mrfixit51
                          Lead Service Technician
                          • Oct 2008
                          • 1975
                          Re: canon mf 4450
                          As Blackcat pointed out, and as you did in this reply, if you cannot originate a phone call with the telephone hooked to this line, you have an issue that needs to be addressed by the phone service provider...
                          Always go to the analog handset when diagnosing possible line problems.
                          • teckat
                            • 16083
                            Re: canon mf 4450
                            Phone provider was never listed/
                            I don't believe poster did the posted line test correct/never posted results
                            if the phone company comes to test and determines inside wire issue>you pay for repair> if it's outside wire issue they pay for repair
                            • George_H
                              Re: canon mf 4450
                              Dear All;
                              let me say it again, i can not dial any number from this machine from any kind of phone line.
                              the issue is not in the company phone. it is in the machine itself.
                              who will be the man who will give me the correct solution
