Can not format HDD - iR3300
I tried many times to format HDD from SST 3.35e, but nothing happens. Either there is a timeout (145 code), or something else. I'm reading the SST manual, but it does not help. As I found out, the only way to format HDD is via Bi-Centronics cable. What is a "Bi-Centronics"? I got a normal centronics cable, which is used to connect my desktop PC to my old HP LaserJet 6L (it's still alive :-))
When I tried network mode (with fixed IP), it didn't work. I gave to the laptop the following IP|: 172.16.1.5 (as the manual says that the machine has a default IP 172.16.1.100). Then tried "Network" mode, instead of "Bi-Centronics", but no luck again. Could you please, give instructions to me (of course, if anyone from you is familiar with this problem).
Maybe some of you have this type of printer/copier. I would be grateful, if you could give me cloned HDD image. In this case, I would write it to an empty HDD, to avoid SST
