imageRUNNER ADVANCE 8105 Series-Address Crepe Image Fault-REVISED
  • teckat
    • 16083
    [CQ] imageRUNNER ADVANCE 8105 Series-Address Crepe Image Fault-REVISED
    New Type Pressure Roller to Address Crepe Image Fault/Publication has been revised to include an example and alternate definition of “crepe” image fault.
    A crepe/blurred image fault may occur after several hundred consecutive sheets of LTR-R / LGL / LDR-size paper passes through the fixing assembly. This symptom can occur on both text and half tone images that require a higher than normal toner yield.
    SEE PDF>>>>>>>>>>>TP11-2.pdf
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: imageRUNNER ADVANCE 8105 Series-Address Crepe Image Fault-REVISED
    • vigour
      • Aug 2010
      • 1038
      Originally posted by zoraldinho
      [ATTACH=CONFIG]11195[/ATTACH]
      IS that what Crepe Image looks like
      I have to start looking for it.
      • teckat
        • 16083
        Spy glass.jpgthat's it
