Canon Ir105 usb to parallel cable..HELP!
  • teckat
    • 16083
    #16
    Re: Canon Ir105 usb to parallel cable..HELP!
    instructions already posted>
    USER MODE KEY*/ADD FUNCTION KEY* all same Crap
    poster is confusing Safe Mode with SERVICE MODE
    If u can't get into service mode> one of those KEYS is stuck or broken> u should here a slight click when depressed-
    • vigour
      • Aug 2010
      • 1038
      #17
      what is your main GOAL? is just to make it print?
      Are you trying to download firmware because you want to, or because the copier has a problem?
      • vigour
        • Aug 2010
        • 1038
        #18
        Originally posted by Lasersupplies
        Hi, thanks for your help but still no joy. As i stated i am new to the canon ir105. I have tried adding it through a network cable directly(using a crossover) from my laptop to the ir105. I cant seem to get an i.p address off the 105! is the default 172.16.1.100? do you know how to get the configuration page off the ir105?
        Thanks again
        Teckat do you have graphics of how to print config page and how to set up ip address
        • teckat
          • 16083
          #19
          Additional Functions > Report Settings > Network
          SEE PDF>>>>iR105 8500 5000i Network Guide.pdf
          • Lasersupplies
            • Jul 2011
            • 221
            #20
            Hi Guys, sorry for the late reply but ive been away for a bit. When i go to network settings the only option after is tcp/ip settings then i.p address range settings. Is there anything i can do to get the other network settings i need?
            • tenatal
              • Aug 2011
              • 35
              #21
              hi,
              what do u want ? print or update firmware.
              if want to print then just connect machine with lan cable & set ip address according to network in tcp/ip settings under system settings.
              * > system settings > network settings > tcp/ip settings
              after making settings according to ur network install pcl driver in ur laptop or pc & create a new port as tcp/ip port & give ip address u give in machine. driver will be installed and u can easily get prints from machine.
              if want to update firmware then only usb cable can be used. connet usb cable to laptop & start sst & make settings accordingly and u can update firmware. one thing is important - sst without which u can't update.
              • Lasersupplies
                • Jul 2011
                • 221
                #22
                That is my problem, i dont have the tcp/ip setting in the network options...all i get is I.P Address range settings.
                Is there anyting i need to do to get the tcp/i.p settings? also i have a usb to parallel cable connected to the machine. I send a job to the ir105 and it shows that the job has been sent but i get nothing printed!
                Have you got a step by step guide for updating the firmaware?
                • vigour
                  • Aug 2010
                  • 1038
                  #23
                  sounds like you might have or have had a RIP attached to your machine.
                  go into service mode *28*
                  press copier
                  then option
                  then int-face
                  then img-cont
                  if you have no rip it should be 0.
                  you say you have usb to parallel cable attached.
                  parallel printing does not use an IP address
                  only lpt1 or 2 ,
                  your cable might need some funky port, that should setup with a driver.
                  • vigour
                    • Aug 2010
                    • 1038
                    #24
                    to print ip address, press additional functions > report > network.
                    If there is no report button, you have to print configuration from your rip.
                    what driver are you using.
                    • Lasersupplies
                      • Jul 2011
                      • 221
                      #25
                      Right guys ive done a reset on the card and i now have the option to add an i.p address which i successfully done. The 105 pings my laptop but when i go through the add printer and put in the i.p address of the machine it does not find it, yet i can ping both ways?! i have auto detect enabled. Does anyone know where i am going wrong?
                      Thanks Guys
                      • Lasersupplies
                        • Jul 2011
                        • 221
                        #26
                        also has anyone got the driver i need for this. i do have one but not sure if its the right one.
                        Thanks again
                        p.s looking to use it through the network
                        • teckat
                          • 16083
                          #27
                          Nethawk driver is now in>C:\Canon\ServiceSupportTool\inf\USBPAdp
                          on newer SST versions
                          early versions of SST
                          The folder will be located in the directory where you installed the Service Support Tool. By default, it will be located in C:\ProgramFiles\ServiceSupportTool\inf\USBPAdp.
                          Please be aware that for later versions of Service Support Tool, the USBPAdp folder will be located by default in C:\Canon\ServiceSupportTool\inf\USBPAdp. Also be aware that this path will be subject to change if the Service Support tool was installed in another directory.
                          • vigour
                            • Aug 2010
                            • 1038
                            #28
                            Originally posted by tenatal
                            hi,
                            iR105
                            • Lasersupplies
                              • Jul 2011
                              • 221
                              #29
                              Hi guys thanks for all the help but still at a loss.....
                              I have the IR105 on the same netowrk as my laptop. Ir105/192.168.0.3 Laptop/192.168.0.4.
                              i can ping both devices from each other but can not print.
                              I installed canon netspot installer and it picks the i.p address but says under product name: SNMP disabled device although i do have snmp set to enabled and community name set to public.
                              I have everything set up correctly but it wont print. do i need to clear or change anything in service mode?
                              • Lasersupplies
                                • Jul 2011
                                • 221
                                #30
                                Hi guys, this is the network report from my ir105....can anyone see anything wrong here?
