IRC 3220 cannot cancel e-mail scan jobs
  • sue2955
    • Jun 2025
    [Jamming] IRC 3220 cannot cancel e-mail scan jobs
    Sent a scan job via e-mail not knowing network was down. It hung with message saying "converting image, network TX". Tried power down and unplugged all connectors, still can't cancel the job. Appreciate any solution.
  • teckat
    • 16083
    Re: IRC 3220 cannot cancel e-mail scan jobs
    On control panel
    Press [System Monitor].
    Press [Send].
    Press [Status].
    Select the job to be canceled >press [Cancel].
    If the job that you want to cancel is not displayed, press [UP] or [DN] to scroll through the list.
    You cannot select multiple jobs and cancel them all at once. Select and cancel one job at a time.
    If a job is in the process of being sent, it may not be canceled even if you press [Cancel].
    The message <Is it OK to cancel?> appears on the touch panel display.
    Press [Yes].
    The message <Canceling...> appears for approximately two seconds on the touch panel display.
    The send job is canceled.
    The canceled job is displayed as <NG> (No Good) on the Log screen.
    Press [Done].
    • sue2955
      Thank you for quick response. I tried that procedures several days ago and today. Still can't cancel job
      • teckat
        • 16083
        can u see in the RUI
        • sue2955
          yes, 4 jobs in RUI ( Top one's status is "sending", the rest is showing "waiting")
          • teckat
            • 16083
            u can try this if familiar with service mode>
            Print out the User Data Lists, P-Print and any other prints that may contain User Settings before clearing MMI.
            Clearing MMI
            1) Go into Service Mode level 1.
            2) Hit Copier.
            3) Hit Function.
            4) Hit Clear.
            5) Hit MMI and select OK.
            6) Wait for the OK button to return and reboot the copier.
            If 'Check The TCP/IP' occurs after clearing MMI follow this procedure to restore the imagePASS C1 function:if one is connected-
            1. In service mode Copier/Option/Int-Face/Img-Cont: Set Img-Cont to = "3"
            NOTE: (Set to 3 and press OK again even if it is already at 3).
            2. Turn the machine off then on again, this will resolve the 'Check The TCP/IP' display.
            3. Turn the power of the imagePASS C1/C2 off then on again if it has a power switch>otherwise use the shutdown method under Printer tab.
            (Check the display under printer option to make sure the imagePASS C1 comes to an idle state).
            NOTE: If the machine displays the message 'turn off and on the main power switch' do so and check the printer option screen again for an idle indication.
            • sue2955
              Hi ! I went to Additional Function -> Report Settings -> Network -> User Data is grey out. What other commands to print out user settings.
              • teckat
                • 16083
                Cancel those waiting to print docs , if u can
                The User Data List button is grayed out
                The User Data List cannot be printed out.
                Solution :
                Verify that the machine is not out of paper.
                The User Data List button is grayed out. The User Data List cannot be printed out.
                Solution :
                Verify that the machine is not out of Letter paper.
                or
                To Set Drawers as Eligible to Print the User Data List:
                1. Hit Additional Functions.
                2. Press Common Settings.
                3. Hit Drawer Eligibility for APS/ADS.
                4. Select Other.
                5. Set the drawers that you wish to be able to print the User Data List to ON.
                6. Press OK.
                if ok/ just do the clear MMI Procedure-
                II. Perform a clear of the MMI memory for the control panel. To clear the memory:
                1. Enter service mode by hitting Additional Functions, the 2 and 8 keys simultaneously, and then Additional Functions.
                2. Select Copier.
                3. Select the Functions tab.
                4. Select the Clear option.
                5. Select MMI and hit OK.
                6. Hit Reset to get out of service mode. The copier will prompt you for a Department ID and Password. Ignore this and Reboot the copier by switching off the main power switch.
                * This solution only fixes the User Data List issue when the button is grayed out. If the button is missing or the Report Settings button is missing, there may be another problem, possible that the NIC is not installed or functioning.
                • sue2955
                  After Clearing MMI, I got 'Check The TCP/IP' message
                  I set img-cont to "3" and turn the machine off and on again.
                  The panel stuck at 'wait' for 10 mins.
                  I turned the machine off and on again.
                  Now still stuck at 'wait'
                  I don't think there is imagePass C1 on my copier.
                  Thank you for your patience guiding me thru.
                  • teckat
                    • 16083
                    If there is no imagePass C1/2 on back of printer>
                    In service mode Copier/Option/Int-Face/Img-Cont: RE-Set Img-Cont to = "0"
                    THEN POWER OFF/On printer
                    • sue2955
                      Yes, I don't have imagePass C1.
                      How do I get out of 'wait' to re-configure img-cont ?
                      I tried addition function -> 2 & 8 -> addition function while booting up.
                      The screen panel and key pad got lock up , I can not change anything.
                      • teckat
                        • 16083
                        yes, i don't have imagepass c1.
                        How do i get out of 'wait' to re-configure img-cont ?
                        The screen panel and key pad got lock up , i can not change anything.
                        you have to be fast/
                        power up /when u see splash screen almost finished-
                        be prepared to enter service mode quick
                        u can do it/ it takes a little practice/ u may have to power off/on a few times to get in
                        • sue2955
                          teckat,
                          Thank you for all your helps !
                          The technician had to replace a hard drive to fix the problem
                          • teckat
                            • 16083
                            teckat,
                            ELVIS.jpgup and running, is GOOD
                            • junkiemanxl
                              • Dec 2007
                              • 49
                              i have had similar problems as well on IRC3220/3200.
                              My solution for this is to
                              • backup data using rui
                              • enter service mode level 1
                              • clear MNCON
                              • restart copier and input the IP address & restart
                              • Restore data using RUI
                              Weirdly, this has been happening to me for the past 2 weeks and all of them have the same characteristics. 6 machines and counting. All hangs when scanning to email and is stuck at converting image.
                              anyone have any idea why this happens?
                              Any solutions for prevention?
