Re: IRC 3220 cannot cancel e-mail scan jobs
Scanning to Email, slows down depending what type of document u are sending-
could be a font issue,communication issue-etc,etc
your procedure takes too much time,
call a Canon trained tech to investigate -----
Install a Layer 2 Switch for Speed
speed increase with the layer 2 switch is a result of the operating characteristics of the switch.
First, let's explain that data throughput problems on a computer network may be caused by many factors. A good test of this is to connect with a crossover cable. If you notice an improvement, you may want to demonstrate the difference for the customer or IT person who is responsible for the network. At this point, whoever is responsible for managing network traffic can address the issue.
The improvement in throughput with the use of a layer 2 switch has an easy explanation. When any device or node, in our case a print device, is connected to a layer 2 switch, the device receives the full amount of bandwidth the network supports. This is an operating characteristic of a layer 2 switch.
In this particular case, the device was connected to a network consisting of a number of hubs with a number of devices connected to each of the hubs. All of these devices belong to the same collision domain. Normally, there are mechanisms in place for devices to avoid collisions with each other while sending data within the same collision domain. You may reach a point where you have too many devices connected and data collisions occur. When this happens, a significant amount of bandwidth is used with the result of reduced overall throughput.
We must also note that other factors are involved, such as cost. Layer 2 switches are more expensive than hubs. The IT professional is the person who will ultimately decide the structure of the network and will do so in accordance with the approval of the customer. This basically means that we will not suggest what type of connections should be used while considering the infrastructure of a network. The purpose of this discussion is to explain why a particular cause and effect pattern was noticed.
Often the IT professional who manages the traffic on a network will be aware of how to troubleshoot these types of problems. In some cases, where a little help is needed, it may be best to demonstrate using a laptop and crossover cable and let the IT professional who is responsible for the network to make determinations on how to improve traffic on the network.
