IR 210S scan error of 2510
  • pananut
    • Jun 2025
    [Error Code] IR 210S scan error of 2510
    Good Day to all. When copying from ADF, machine functions fine. When trying to fax from ADF it has a 2510 scan error. Can fax from glass with no errors.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Re: IR 210S scan error of 2510
    Have not seen this, search at Canon turned up zilch.
    The DADF uses different belts when faxing than when it is copying,,, try cleaning with paper that has the leading edge wetted with alcohol. Go into fax area, tools, use the test scan, to engage the correct set of belts to the soaked paper...
    • teckat
      • 16083
      what happens on a copy glass scan for a fax
