IR C2620 laser motor unit E000110-0110
  • Smartmind
    • Aug 2011
    • 61
    [Error Code] IR C2620 laser motor unit E000110-0110
    Hello to all, Well, turning on my Canon c2620 until warming up shows an error E000110-0110 that means that there was a problem with the color laser motor, i did check that unit and i found some bugs in there, obviously the laser got damage, but now i haven't find the laser unit part Number to order it, any help please!!! i'll apreciate it!
  • teckat
    • 16083
    Re: IR C2620 laser motor unit E000110-0110
    that is your YELLOW unit=Laser Unit: FG6-8962-000,all colors have same #
    if your machine serial# starts with MSN,or RQY/your part# is FM1-0357-000
    E110-0x10
    1=Y
    2=M
    3=C
    4=BK
    to fully check this Laser Unit swap with another color
    -and ,because a Faulty Fuse pcb can also contribute to the error,check it also
    1. Swap the affected laser unit with others.
    2. Check whether or not the sub code of E110 will be changed.
    - If the sub code is changed, the laser unit is faulty. So, replace it with a new one.
    - If the sub code is not changed, it is possible that the DC controller PCB is faulty
    make sure your ITB is rotating
    check connection position of J114 ON DC PCB,this is for YELLOW LASER
    these cables are from Lasers to DC CONTROLLER
    J114-YELLOW
    J116-MAGENTA
    J118-CYAN
    J120-BLACK
    • Smartmind
      • Aug 2011
      • 61
      Thanks a lot Teckat! now i got the part number. I aprecite your help.
      • teckat
        • 16083
        good luck~~~~~~~~~~~~~~~~
