irc 3080i E003-01
  • flyinblind
    • Aug 2025
    irc 3080i E003-01
    To all you aces out there, I Have a irc 3080i with an intermittent E003-01 code. Replaced the fixing assembly,sw3,DC controller,main power supply RD upper and lower cap mod. to no avail. any ideas would be thoroughly appreciated!!!! Thanks.
  • its_just_a_copier
    • May 2011
    • 132
    Re: irc 3080i E003-01
    How about the DC Driver PCB?
    That's the one that takes signals from the thermistors...
    also, I gotta ask: Customer Power?
    • flyinblind
      Customers power checked out ok. I'll give the DC driver a try.
      • teckat
        • 16083
        CHECK THIS
        SW3 is the Fixing unit's AC interlock switch. Sometimes the right door actuator will be bent and not fully press SW3 when the right door is closed. SW3 is a button switch located right above some of the Fixing unit's rear frame connections. SW3 has been found to show signs of wear and have carbon build up inside it. If the right door actuator is straight and making good contact , inspect SW3 and it's AC connections. If any flaws are found after inspecting SW3, replace it. SW3's part number is, FM2-9427-000
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          Also an oddity I ran into last week could be a contributing factor. The upper bracket that is part of the right door hinge, the part near this actuator, was broken, and the door did not hang correctly. The steel had fractured, probably by the customer over extending the door when opening it. It had been jamming a lot. It was the kind of break you see from metal fatigue when something is flexed over and over till it breaks...
          It is item #24
          • flyinblind
            Turned out to be a faulty rebuilt fixing assembly. One of the those curve balls, thrown my way!!!
            • teckat
              • 16083
              repair_testequipment.gifget the money back
