IR3570 SPOTS
  • bunnthebody
    • Oct 2008
    • 38
    IR3570 SPOTS
    I am working on a ir3570 that has spots on the platen copies, spots on the adf copies and no spots on the prints. It has to be the scanner. We cleaned the optics and reset the ccd to no avail. Is there a way to adjust the scanner or do we need new parts. The copies are darker than the prints and have small dots all over them. Any help would be appreciated.
  • Mina Banoub
    • May 2011
    • 50
    Re: IR3570 SPOTS
    start service mode level 1, copier , adjustment, develop (change the value of DE- OFST in the negative direction) this might help you fix the problem also make sure that the customer is using an original canon toner.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Re: IR3570 SPOTS
      Originally posted by Canon.Tech
      As above poster said, are you using genuine Canon supplies?
      You get black spots with the pirate toners & drums.
      No spots on the print!
