[Error Code] Canon IR 4080 Code - E000100-0202
  • CopyBats
    • Aug 2011
    • 147
    Hi, I am a Ricoh Technician and I am fairly new to this forum. One of our customers has a Canon Image Runner 4080 and it is giving problems. When you turn the machine on, the Canon logo appears, and the home screen loads up. However, all of a sudden displays the error code E000110-0202. Machine then asks to shutdown and restart again. After turning off the machine and then turning it back on, the error code shows up right after the canon logo loads up.
    Any help in this matter would be appreciated as I am clue less when it comes to Canon.
    If it works, don't touch it.
  • gensys
    • Jan 2011
    • 323
    Re: [Error Code] Canon IR 4080 Code - E000100-0202
    The temperature of the fixing assembly is abnormally high
    Inspect the fixing assembly
    Copier > function > clear > error
    The Road will be Mastered by >>> the Going...
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Re: [Error Code] Canon IR 4080 Code - E000110-0202
      E110 Polygon error
      1st line: Always 0
      2nd line: Station where the error occurred (1: Y, 2: M, 3: C, 4: K)
      3rd line: Main unit status when the error occurred (0: Activating, 1: Correcting the image position, 2: Changing the speed, 3: Operating steadily)
      4th line: Polygon control status (0: Suspension, 1: FG rotation, 2: BD control 1, 3: BD control 2, 4: BD control 3, 5: BD control 4, 6: Phase locked
      0xx2 A BD signal has never been detected.
      (It may be caused by damage to the laser PCB/BD sensor or removal of
      the harness.)
      (1)Check whether the harness is not removed.
      (2)Replace the scanner unit. (Laser Assembly)
      (3)Replace the harness.
      (4)Replace the DC controller PCB 1 (IMG).
      (5)Replace the power unit.
      • teckat
        • 16083
        U got it wrong_E000110-0202= MAGENTA LASER ISSUE
        • Herrmann
          • Jan 2006
          • 792
          to isolate the error, interchange the cyan with the magenta laser unit and see, if the code changes to 0203
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
