imagePRESS C1/C1+/Rev.Measures Against Developer Overflow/& Carrier Adhesion to Media
  • teckat
    • 16083
    [Misc] imagePRESS C1/C1+/Rev.Measures Against Developer Overflow/& Carrier Adhesion to Media
    imagePRESS C1/C1+
    Measures Against Developer Overflow or Carrier Adhesion to the Output Media
    Publication has been revised to update Workflow A and Workflow B.
    This Technical Publication outlines procedures to minimize Developer Overflow or Carrier Adhesion to the
    output media caused by improper use of the INIT and INISET functions.
    During routine maintenance or machine installation, if INIT or INISET are used incorrectly it can result in
    Developer Overflow or Carrier Adhesion to output media.
    The activities listed in the PDF matrix below will clarify when each Service Mode should be used.
    SEE PDF>>>---TP10.pdf
