Here's a video clip of my pain in the ...IR550
  • Merv
    • 63
    I had my two boys watch the print run and they had a paper jam. They cleared it and when it started up againg it developed this knock.
    Only when the machine starts up and runs through its warm up cycle and during a print. A rapid fire knock.
    I have pulled apart the back, lifted out the developer units, looked for wear patterns, pulled the circuit board out and checked the components behind it. I've spent hours upon hours looking and I am stumped. so I took a video clip of it and thought maybe someone here has heard this before. I can't upload a video to this site so I uploaded it to my site, watch it here. Terrace Daily: Articles
  • JR2ALTA
    • Feb 2010
    • 2028
    Re: Here's a video clip of my pain in the ...IR550
    Man, this happen after your techs worked on it? It can't be that difficult. I spend 2.5 hours on a damn little chirp squeak and you can't find an enormous rattling sound?
    Sounds like gear mesh to me.
    • vigour
      • Aug 2010
      • 1038
      sounds like a metal plate rattling, when a roller is turning
      pull the transport out, turn reg roller by hand, and see what happens, see if spring is stretched, or loose, check bushings.
      or check the the sponge roller bearings in the pre-reg area
      • Merv
        • 63
        Thanks for all the responses. This knocking sound happens at a cold start up. As soon as I power it up and turn it on it goes through a cycle that this noise is coming from.
        It doesn't have to be printing to start making the noise. I have opened all the paper cassettes just before starting and that made no differennce.
        The paper didn't rip when it jammed but I lifted out the duplex tray and the entire transfer unit checking everywhere. I manually turned all the gears and rollers I could locate and get to but couldn't get any noise.
        If I knew just what rotated first, or cycled first at the initial start, this would at least narrow my search down a bit.
        What cycles first at start up?
        • Merv
          • 63
          Here is a pic showing the exact spot the knocking is coming from, behind the plate the tip of the screw driver is touching. Looks like a hell of a procedure to get into that area. ir 550 knock spot.JPG
          It is hitting so hard there it almost moves the screw driver when I touch the metal plate.
            • 16083
            Think this is for your Model/ had from old paper work/ it may be for iR600, lost top page
            COPIER>FUNCTION<PART-CHK>
            Check the Operation of Loads
            CL
            Selecting the Clutch to Check
            Operation
            1) Select CL.
            2) Using the keypad, enter the code of the clutch. (See
            the code table that follows.)
            3) Press the OK key.
            CL-ON
            Checking the Operation of the Clutch.
            Operation
            1) Select CL-ON, and press the OK key.
            ON ! 10 sec OFF ! ON ! 10 sec OFF ! ON !OFF
            MTR
            Selecting the Motor to Check
            Operation
            1) Select MTR.
            2) Using the keypad, enter the code of the motor to
            check. (See the code table that follows.)
            MTR-ON
            Checking the Motor
            Operation
            1) Select MTR-ON, and press the OK key.
            10 sec ON ! OFF
            SL
            Selecting the Solenoid to Check
            Operation
            1) Select SL.
            2) Using the keypad, enter the code of the solenoid.
            SL-ON
            Checking the Solenoid
            Operation
            1) Select SL-ON, and press the OK key.
            ON ! 10 sec OFF ! ON ! 10 sec OFF ! ON ! OFF
            CLUTCHES
            1-Manual tray pickup clutch (CL7)
            2-Cassette 3 pickup clutch (CL12)
            3-Vertical path 3 roller drive clutch (CL13)
            4-Cassette 4 pickup clutch (CL14)
            5-Vertical path 4 roll drive clutch (CL15)
            6-Front deck (right) pickup clutch (CL10)
            7-Vertical path 1 roller drive clutch (CL8)
            8-Front deck (left) pickup clutch (CL11)
            9-Vertical path 2 roller drive clutch (CL9)
            10-Pre-registration roller drive clutch (CL5)
            11-Lower feeding middle roller drive clutch
            (CL16)
            12-Lower feeding right roller drive clutch
            (CL17)
            13-Front deck (left) feeding clutch (CL19)
            14-Delivery speed switching clutch (CL21)
            15-Registration roller brake drive clutch (CL3)
            16-Manual feed tray feeding clutch (CL18)
            17-Hopper drive clutch (CL1)
            18-Developing cylinder drive clutch (CL4)
            19-Registration roller drive clutch (CL2)
            20-Side paper deck feeding clutch (CL101)
            21-Side paper deck pickup clutch (CL102)
            MOTORS
            1-Drum motor (M0)
            2-Main motor (M1)
            3-Pickup motor (M2)
            4-Fixing motor (M3)
            5-Laser scanner motor (M4)
            6-Cartridge motor (M6)
            7-Hopper motor (M18)
            8-Horizontal registration motor (M15)
            9-Duplexing reversal motor (M11)
            10-Duplexing feeding motor (M12)
            11-Side paper deck main motor (M101)
            SOLENOIDS
            1-Front deck (right) pickup solenoid (SL7)
            2-Front deck (left) pickup solenoid (SL8)
            3-Cassette 3 pickup solenoid (SL9)
            4-Cassette 4 pickup solenoid (SL10)
            5-Manual feed tray pickup clutch solenoid
            (SL6; push)
            6-Manual feed tray pickup clutch solenoid
            (SL6; pull)
            7-Delivery flapper drive solenoid (SL3)
            8-Reversing flapper drive solenoid (SL11)
            9-Fixing inlet guide drive solenoid
            (SL1; push)
            10-Fixing inlet guide drive solenoid (SL1; pull)
            11-Fixing cleaning belt drive solenoid (SL2)
            12-Fixing feeding unit locking solenoid
            (SL4; push)
            13-Fixing feeding unit locking solenoid
            (SL4; pull)
            • Merv
              • 63
              problem solved Re: Here's a video clip of my pain in the ...IR550
              Well i asked the boys, did the paper rip? and they said nope, just pulled out the sheets. The knock came because the gear driving the waste pick up auger couldn't turn and the gear snapped back as it had to or it would break. The auger wouldn't turn cause there was paper wrapped around it.
              Here's some pictures. It took a while but I learned a lot, don't believe everything you're told is just one
              where noise came from off.JPGspring compressed.JPGpaper jam.JPGpaper removed.JPG
              Thanks for all the ideas and help. Maybe me sharing these pics will help other newbie techs like myself.
              I always told the boys, if the paper rips lay out the pieces and make sure you have every piece before you start it again.
              This cost me two good days of production, I didn't have the time to keep looking steady for the problem.
              On things for sure, I know a lot more about the machine. Good thing I have two more for spare parts!
                • 16083
                AMAZING
