Canon IR 3200-C1 duplex registration/calibration
  • dada2199
    • Aug 2011
    • 31
    Did a search and found nothing specific to the IR 3200 with the C1 RIP and calibrating back-to-front duplex registration.
    A single-sided sheet is off by well over 1/8" in terms of image centering on the page, so duplex is WAY off (1/4" or more).
    My previous IR 3200 that died was perfectly calibrated probably 18 months ago, and we never had to touch it since then, so I've since lost the knowledge of the right steps.
    Thoughts?
  • dada2199
    • Aug 2011
    • 31
    Re: Canon IR 3200-C1 duplex registration/calibration
    Digging through the printer's menu (NOT the C1 menu):
    * Additional Settings
    - Printer Settings
    -- Settings
    --- Layout
    ---- Offset X / Offset Y
    Seems to work for single-sided prints. Will test it on duplex next.
    • dada2199
      • Aug 2011
      • 31
      Duplex is pretty close, maybe 1/16" off in the Offset Y direction, but WAY better than before.
      If anyone has any more pointers that I'm forgetting, please post for future search sake. I vaguely remember tray calibration but can't remember if that was a Xerox, Canon or Ricoh issue.
      • vigour
        • Aug 2010
        • 1038
        tray calibration is done from the fiery
        you can fine tune each tray
        for duplex side to side on the copier
        copier >adj> feed adj>refe
        that is the short cut
        there is a long more complete process
        • dada2199
          • Aug 2011
          • 31
          Yep, that did it, thanks!
          - Went to Printer tab (main menu on printer)
          -- Printer Status/Settings button
          --- Functions button
          ---- Tray Alignment (second page)
          It's near perfect now, maybe 1/64th inch skew.
          THANKS!
          • vigour
            • Aug 2010
            • 1038
            da--, you are fast
            • dada2199
              • Aug 2011
              • 31
              Too many years beating up printers -- also too many years of conflicting information in my skull. How I missed the Fiery tray calibration menu this weekend is beyond me.
              Next step is to get the skew conquered, but it's not a production printer so perfection isn't important!
              • vigour
                • Aug 2010
                • 1038
                good luck.
                it is within spec.
                try doing the tray adjust a couple more times.
                there is a nut and screw on the duplexer for skew adjustment.
                good luck with that
