iRADC9075PRO / C9065PRO / C7065 and C7055-Preventing a Ghost Image in Low Temperature Environments
In a low temperature environment, a ghost image may occur due to ATVC control which affects the Primary Transfer Roller.
This phenomenon occurs at 96mm intervals in the paper feed direction and may affect the Yellow,
Cyan or Magenta Primary Transfer Rollers.
SEE PDF>>>>
-TP11-1.pdf
Measure to Correct an Error with the Drum and Primary Transfer Rollers Counters
Publication describes a measure to correct the Yellow, Cyan and Magenta Drum Counters and Primary Transfer Roller Counters from accidentally incrementing when printing B/W only.
SEE PDF>>>
-TP11-2.pdf
SEE PDF>>>>
SEE PDF>>>
