Canon IR 2270 Jam from Cassette 1
  • TonerApe
    • Jan 2008
    • 26
    [Jamming] Canon IR 2270 Jam from Cassette 1
    Need to bounce a question off the group mind.
    I have a 2270 that refuses to bring the paper up to PS10. I have recently replaced all the tray pickup rollers, the vertical path roller, and the one-way clutch on the vertical path roller.
    I have also been through the entire COPIER>FUNCTION>PRT-CHK and all motors, clutches, and solenoids pass internal tests.
    Perhaps someone with more experience with this unit than me would be willing to give me a gentle nudge in the right direction
  • teckat
    • 16083
    Re: Canon IR 2270 Jam from Cassette 1
    replace the flag =FB6-3399-000 and the wrap spring=FS7-2803-000
    replace torque limiter with old type part # RB1-6588-000
    • TonerApe
      • Jan 2008
      • 26
      Thanks for the advice ... I will check into that and let you know
        Have the door mods been done
        FM3-1297-000 RIGHT LOWER INNER DOOR ASSY
        FM3-1296-000 RIGHT LOWER DOOR ASSEMBLY
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          As a diagnostic, I will from time to time swap cass1 paper feed unit with cass2 unit. You have to swap the rear metal bracket and the guides, but it certainly will point to the problem if your trouble now switches to cass2...
          • teckat
            • 16083
            images.jpgglad someone plugged in
