canon IR2018 adding toner
  • sjinachandran
    • Aug 2025
    Dear friends,
    i have faced the problum of adding toner in ir2018, i cleaned the developer unit and replaced the new toner, machine works for 10 copies and it shows adding toner, some times machine works fine, where to analise.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: canon IR2018 adding toner
    Read pdf.........ir2030-004.pdf
    • gensys
      • Jan 2011
      • 323
      Clear the sensor of dev.unit & Check the Gear Holder
      The Road will be Mastered by >>> the Going...
      • gensys
        • Jan 2011
        • 323
        Originally posted by zoraldinho
        Read pdf.........[ATTACH]11426[/ATTACH]
        Thanks for a Service Bulletin
        • sjinachandran
          Tku u for the reply friend, the problum occures due to shaft of the mac roller deformed, changed the roller and the problum fixed
          • zoraldinho
            • Mar 2008
            • 5015
            Roller???
