black color to strong, can feel the print on the paper , all other colors are fine. unit has a new drum still the same thing. did I miss a adjustment?
canon IRC 5185
Re: canon IRC 5185
Auto Gradation Adjust?
Did you have this problem before replacing the drum? If so then you must swap primary transfer rollers or laser unit... -
Re: canon IRC 5185
By the sounds of it you are losing strarter from your drum units. Are these rebuilt drums or OEM? and what kind of toner is being ran through the machine.
You could also have a BIAS issue.Accidents don't just happen. They must be carelessly planned.Comment
Re: canon IRC 5185
Went to Adjust , Dens, All I see is P-ALPHA ?
I am using Oem Parts ,Had the issue before changing the drum unit , all other color are fine just the black I am having the issue. I have scan a copier of a printed page copy_20110825140656.pdfComment
