iRC 3180i
  • dibyendu
    • Jan 2011
    • 53
    [Error Code] iRC 3180i
    i have irc3180i showing error code E00070-003. as per manual i cleaned itb home position sensor but problem not rectified. plz. help me ........................
  • charm5496
    • 2387
    Re: iRC 3180i
    you might need a new belt assembly if the machine can not see the belt rotating correctly.
    When you turn it on did you check and see if you are getting any rotation on the belt?
    • godyng
      • Dec 2008
      • 40
      Re: iRC 3180i
      Check the timing roller grounding!!
      • dibyendu
        • Jan 2011
        • 53
        Re: iRC 3180i
        there is good rotation of belt i have seen, therefore belt assembly is not needed. any other idea.................................
        • charm5496
          • 2387
          Re: iRC 3180i
          if the belt is worn and the sensor can not see the belt rotating then you will need to replace either the belt assembly or the HP sensor
          • mrfixit51
            Lead Service Technician
            • 1975
            Re: iRC 3180i
            Charm has mentioned twice for the need of a new belt, I too believe that is the answer. It is not so much about the movement of the belt as much as dirty sensors or worn white patches on the inside of the belt not being detected.
            Cleaning the sensor and replacing the ITB belt has always resolved this issue for me...
            • dibyendu
              • Jan 2011
              • 53
              Re: iRC 3180i
              thank you everybody the problem solved with timing roller grounding clip. i have cleaned both 2 grounding clip and solved the issue. thanks everebody.......
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5015
                Re: iRC 3180i
                • mrfixit51
                  • 1975
                  Re: iRC 3180i
                  Are you referring to the grounding strap that rides on the paper feed steel registration roller that uses the black conductive grease??
