Canon IR 2800 E602-0003 Problem
  • niallw
    • Jul 2025
    [Error Code] Canon IR 2800 E602-0003 Problem
    Hi
    I have a Canon IR 2800 and it has the E602 -0003 error. I believe this is a hard drive fault. I have rand my local repair centre in Ireland and they have told me the machine part can no longer be got. I see i can order the hard drive on ebay. Can anyone point me in the direction of were to get the software for this machine and is it hard to install this. I am more use to repairing PC's than photocopiers.
    Niall
  • charm5496
    • 2387
    Re: Canon IR 2800 E602-0003 Problem
    you will need firmware for the machine, a Proprietary software to load it and a special cable to connect your PC to the copier. If this is a one time deal just call your local canon provider and have them take care of it.
    • itmah
      I'm very new to copiers overall but guess there's just some trouble with the HDD itself. E602-0003/2 will go back to normal in almost 100% of the cases with a new harddrive. Also the firmware versions differs between machines with network and those without. if you got access to a disc drive duplicator and just got one disc that's working this should be solved in about 15 min.
      • charm5496
        • 2387
        good response but next time try responding to a more current post as this thread was never responded to by the original poster almost 2 months ago.
        welcome aboard and good luck out there working on those Canons
        • itmah
          Oh, hehe, Thanks and i'll try to look at that in the future
