NP 6512 - E001
  • Smiley27
    • Apr 2011
    • 160
    [Error Code] NP 6512 - E001
    Getting this error msg.
    History :
    Before this happend,scanner lamp scanned just to half of a4 and stoped..worked fine,but just for A5 lol ... I have no idea what could be cause of lamp to stop on half ...
    Can some1 tell me what thiis error means?
    and also,i cant get drum unit out,it seems to be stuck in there...
  • charm5496
    • 2387
    Re: NP 6512 - E001
    you need to get the developer out of the way first in order to remove the drum.
    The e001 code is a fixing temperature error. With this old beast it could be anything from weak heater in the film, to dirty thermistors or a power supply going bad. best bet is to look at film assembly to see if it needs replacing and then move on from there
    • doktor
      • 214
      Re: NP 6512 - E001
      Try this.6512.pdf
      • teckat
        • 16083
        Re: NP 6512 - E001
        History :
        did u have any type of voltage drop in the office/ or power loss/ during printing ?
        • gensys
          • Jan 2011
          • 323
          The Road will be Mastered by >>> the Going...
          • theBAU
            • Mar 2010
            • 8
            Re: NP 6512 - E001
            Try to reset first this error(usually is from fixing ass'y) from the DC controller PCB.(Turn off the power switch, and short circuit JP103 and JP104 on the DC controller PCB)
            • teckat
              • 16083
              Re: NP 6512 - E001
              • Smiley27
                • Apr 2011
                • 160
                Re: NP 6512 - E001 UPDATED
                I managed to reset error,and machine works fine NOT ... Next problem is,It does scan job and everything,no jam,but ! paper comes out blank! it probably has something to to with this drum unit that i cant get out .. i get out developer unit,and drum doesnt move,seems like its stuck in there .. btw,thanks for helping me solve first problem
                also,any1have user manual part for this machine where you take drum unit out? lol i am curious ..
                i take those 2 levers down,take out developer,and this shit doesnt move ...
                • Smiley27
                  • Apr 2011
                  • 160
                  Re: NP 6512 - E001
                  Managed to get it out, with combination of brain / force .. thing is,pc roller holder was broken,and it fell of and got stuck in machine lol .. i think thats good enough to make blank copys xD .. so,this time,i just need to replace drum unit
                  thanks for your help guys
                  consider thread as
                  CLOSED
