IRC5185 Blurred Printer
  • ricardobres
    • 147
    Hi guys
    I have an IRC5185 with Blurry printer. This problem occur with copier and printe. I replaced the transfer belt, the drum, I cleaned the tranfer belt unit, and the machine interior, any ideas?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: IRC5185 Blurred Printer
    Blurred image,double image,smeared image.Post a picture of test print please and i believe you can get answer in a sec.
      http://www.copytechnet.com/forums/ca...istration.html
      http://www.copytechnet.com/forums/ca...alignment.html
      • teckat
        • 16083
        Originally posted by ricardobres
        Hi guys
        post copies of the issue-
        post PG6's Grid pattern-this will indicate direction & if it is on single color or multiple colors
        is the issue paper feed>
        (sub-scan/or cross-feed(main scan) ??
        click on pics for a better view
        • ricardobres
          • 147
          This is the sample, and this copy was made on single color (black), if I send a print, the problem persist, and if I change the single color, (cyan, magenta), the prblem is same.
          • teckat
            • 16083
            your posted images are terrible/looks washed out/-also looks like a transfer issue on top of blur
            did u look at my description of paper feed area location above ?
            is your posted image paper feed (RIGHT to LEFT)?
            or cross-feed-(FRONT to REAR)of Printer
            there is a Front to Read issue adjustment/only if u have v79.01 firmware installed-called REG-SPD, REG-SPD2 and REG-SPD3/
            see pdf>open this>>iR5180 Blur_Miss Reg TP09-10.pdf
            here is another tech.pub from other another poster>iRC5180_Color_Shift_Prevention _&_Correction.pdf
            Print out the PG6 -GRID PATTERN/ located in service mode-
            faulty Gears or ITB Motor
