ir 2270 image problem
  • vick
    • Aug 2025
    Hi guys,
    i have problem on Canon iR 2270 model..I no idea how to explain the problem so i attach the sample off image.I already replace drum unit,fixing assembly(film include) and lower roller..All item is original and purchase on Canon Marketing..After everything done,same issue.The problem only after customer do more than 50 copies or print.
    please give me guide...
    TQ,
    Vick......
    20110906134228.pdf20110906134228.pdf
  • dhanesh
    • Jun 2010
    • 63
    Re: ir 2270 image problem
    check ur cd unit try to replace
    DHANESH
    • grandmaster
      • Aug 2011
      • 9
      check the belt tension in main drive unit.
      • teckat
        • 16083
        Originally posted by vick
        Hi guys,
        TQ,
        Vick......
        [ATTACH]11640[/ATTACH][ATTACH]11640[/ATTACH]
        what size paper ????
        Look for toner dropping from between DV unit and Sub Hopper.
        Toner Dropping TP08-1.pdf
        Measure to Prevent Smeared Images on Copies
        Change the value set for the service mode.
        1. Press *> 2 and 8 at the same time, and press >* >*2 to enter Level 2 in service mode. Select COPIER>
        OPTION> BODY> FIX-SMR and change the value to "+2".
        2. Enter Level 2 in service mode, select COPIER> ADJUST> DEVELOP> DE-OFST, and change the
        value to "-10" or "-20".
        Turning ON and OFF the sequence of reducing the copy speed to maintain the fixing performance for copy images
        Level 2 (* 2 8 * then * 2) > Copier > Option > Body and set CPMKP-SW to 1.
        Change the pressure roller to the new type one.
        FC5-7207-010
        The color of the old type pressure roller is brown, and the new type pressure roller is black
        • Arcking1968
          • Sep 2011
          • 39
          Look like you having a jitter in the copy. I encounter in previous model that the tension belt is having a dried toner in it, or it is defective. Try to make a copy in A3 and check if the jitter image is repeating, if this happen try to check the belts or the gears...
          Good luck.
