Canon ir3035 - receiving error on clicking get device status button
  • DekBolt
    • Oct 2025
    Hi All
    A little bizzare this one and im hoping someone may have come across this before.
    We have a Canon ir3035. The print server is a w2k3 server (firewall disabled).
    I have used the drivers from Canon, run through the setup and selected the appropriate driver, installed DIAS and set the printer up.
    I have then allocated the printer through to some Windows 7 stations (firewall disabled). When users logon to the stations and click the get device status button they receive the error could not get device information. If I manually add the printer, IE open devices and printers, click on add printer and then browse active directory for it, it seems to work. Clicking on check device status comes back with got device information and will allow me to input department IDs and print successfully. This happens on any users (incl domain admins).
    Anyone come across this before or maybe shed a little light on this for me??
    Cheers
    DekBolt
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5022
    Re: Canon ir3035 - receiving error on clicking get device status button
    Install again last UFR driver and bee shore to have installed Device Information Assist Service
    • DekBolt
      Yup, I have tried that.
      I uninstalled the PCL driver set and then run through the setup for the UFR II driver set.
      Again I selected DIAS and told it to install that and the same thing occurs.
      If the printer is mapped automatically as part of logon then it doesnt work and I get the error message. If I manually map the printer then all is good.
      DekBolt
      • charm5496
        • 2385
        is DIAS running at the workstation level?
