ip c1 con servidor t1 se corta la conectividad
  • DANIELCANON
    • Jun 2011
    • 187
    tengo el problema que el t1 version 1.01 se conecta todo normal con el comand work station 4 y 5 pero cuando quiero imprimir un archivo y se abre la ventana del driver y estoy en las preferencias configuando el tipo de papel y el origen de papel justo en ese momento se desconcta y el comand work station sale el mensaje de conexion perdida pero pasado aprox 1 minuto intento ingresar al comand work y si se conecta de nuevo y la impresion sale normal, solo se desconecta cuando ejecuto el driver de impresion. me a ocurrido con 2 servidores t1 distintos y en lugares distintos, tanto en window xp y en window 7.
    use los driver para t1 poscrip version 1.0 y 2.0 y ocurria lo mismo pero cuando use el driver image press server t1 pcl5 se corrigio pero la calidad a disminuido porque puede estar pasando esto.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: ip c1 con servidor t1 se corta la conectividad
    Please translate in to English.No help with google translate!
    • teckat
      • 16083
      I have the problem that the t1 version 1.01 connects all the comand normal work station 4 and 5 but when I print a file and open the driver window and I'm in the preferences configued the paper type and paper source just Being knocked that time comand work station and get the message connection lost but after about 1 minute attempt to enter the comand work and connects again, the impression is normal, just disconnects when I run the printer driver. happened to me a different t1 2 servers in different places, both in windows xp and windows 7.
      use the driver for t1 poscrip version 1.0 and 2.0 was the same but when using t1 server driver PCL5 press image was corrected but the quality has decreased because it may be happening.
      • teckat
        • 16083
        The most common reason for this issue has always been a duplicate IP address within the same network. Once this has been completely ruled out, these other alternatives could be considered:
        In Network environments where a Cisco Switch is involved, one approach could be to set the PortFast feature on a Cisco switch. This has the property of negating the effects caused on IPX/SPX and AppleTalk protocols regarding the Spanning Tree Protocol. There have not been any observations so far of the Spanning Tree Protocol causing a problem on TCP/IP networks.
        There have been a few reported incidents where a device appears to fall off a TCP/IP network and is not related to the Spanning Tree Protocol although the symptoms of the problem appear to be the same. In this case, you may isolate your device from the switch or router by adding a small inexpensive hub with no intelligence between the device and switch. Alternatively, you can try locking the switch port and the Canon device at the same network speed. This can eliminate any auto-negotiation issues.
        Try disabling the 'RIP-Then-Print' or 'RIP all then print' option on the Fiery controller.
        Perform the following steps:
        1. Enter Fiery Setup on the imagePASS or imagePRESS Server by selecting 'Run Setup' from the idle screen menu.
        2. If prompted, login with the required Fiery Setup password (the default password is Fiery.1).
        3. On the Fiery Setup screen, select 'Printer Setup'.
        4. Each option under 'Printer Setup' will prompt you for a setting. Enter the appropriate settings as needed.
        5. When you get to the 'RIP-Then-Print' or 'RIP all then print' option, set it to 'No'.
        6. Exit out of Fiery Setup and select 'Yes' when prompted to save changes.
        7. The imagePASS or imagePRESS Server will then reboot itself.
        * You can verify that the 'RIP-Then-Print' or 'RIP all then print' option was disabled by printing a Configuration Page from the Fiery controller. Under 'Printer Setup', you should see the line 'RIP-Then-Print: No' or 'RIP all then print: No'.
        Realice los siguientes pasos:*
        • DANIELCANON
          • Jun 2011
          • 187
          [QUOTE=teckat;244946]The most common reason for this issue has always been a duplicate IP address within the same network. Once this has been completely ruled out, these other alternatives could be considered:
          * You can verify that the 'RIP-Then-Print' or 'RIP all then print' option was disabled by printing a Configuration Page from the Fiery controller. Under 'Printer Setup', you should see the line 'RIP-Then-Print: No' or 'RIP all then print: No'.[/QUOT
          Hola amigo TECKAT nesesariamente estamos trabajando con protocolo TCP/IP. bueno revize lo que me dijiste: RIP ALL THEN PRINT se encontraba en NO. PERO AUN ASI IGUAL SE PIERDE LA COMUNICACION TAMBIEN PROBE CONECTANDO con un cable de red cossover el ordenador con el servidor sin utilizar el switch de red.sigue con el mismo problema. alguna otra idea.
          • teckat
            • 16083
            Hello friend TECKAT proved necessary we are working with TCP / IP. revize good you told me: RIP was ALL THEN PRINT OFF. SAME BUT STILL LOST COMMUNICATION CONNECTING also tested a network cable to the computer cossover with the server without using the switch red.sigue the same problem. another idea.
            is the issue with Windows or MAC PRINTING ?
            is this on all applications when printing ?
            what type of files ? how large ?
            CLICK EN LA IMAGEN PARA VER MEJOR
            Performing this arp -s command string is only a temporary work around in order to further identify if the printing issues might be related to possible duplicate IP address or IP conflicts on the network.
            Please note
            The arp -s command string will be undone if the computer is restarted, you will need to retype the apr -s command string in order to re-instate that function. If the computer is a workstation then we would suggest that you create a batch file with this arp -s command string and place the batch file in the windows startup folder.
            Tenga en cuenta
            • DANIELCANON
              • Jun 2011
              • 187
              el problema es con window y con todos los archivos cualquiera sea probe con otro servidor modelo q1 y trabaja bien, voy a seguir intentando aver que sucede gracias.
              • teckat
                • 16083
                the problem is with window and all files regardless of probe to another server q1 model and works well, I'll keep trying to aver that happens thanks.
                BUENA SUERTE
