reader controller burnt (iR3225N)
  • dilip_22
    • Sep 2011
    • 20
    [Error Code] reader controller burnt (iR3225N)
    Hi everybody,
    Canon iR3225N copier
    Error code E248 , reader pcb was burnt, I removed that pcb without P Print. if i put new pcb and turn on the machine, will it able to work?
    Please can any one help me
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Re: reader controller burnt (iR3225N)
    Originally posted by dilip_22
    Hi everybody,
    You should be able to run a P-Print after replacing that Reader board. The P-Print info is resident on the Main Controller, so the board change will not have an affect on the P-Print.
    • dilip_22
      • Sep 2011
      • 20
      Thanks a lot for the help. I will do it.
      • mrfixit51
        • Oct 2008
        • 1975
        You are welcome!!
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Be sure to output the latest P-PRINT before replacing the reader controller
          PCB.
          -In the case of clearing RAM for the reader controller without replacing the
          PCB, the following adjustment is unnecessary if uploading the R-CON
          backup data using SST and downloading the data after clearing RAM.
          1. Adjustment related to the reader unit
          1)Using SST, download the latest system software (R-CON).
          2)Select the following service mode; COPIER > FUNCTION > CLEAR >
          R-CON,
          hold down OK, and then execute RAM clear. After that, turn off/on the
          main power switch.
          3)Enter the values of the following items in service mode.
          a. Value on the service label (inside of the reader left cover)
          a-1.Adjusting the CCD reading position (in fixed reading)
          COPIER>ADJUST>ADJ-XY>ADJ-X
          a-2.Adjusting the position in main scanning direction (in fixed reading)
          COPIER>ADJUST>ADJ-XY>ADJ-Y
          a-3.Adjusting the shading position (in fixed reading)
          COPIER>ADJUST>ADJ-XY>ADJ-S
          a-4.Value of MTF in main scanning direction
          COPIER>ADJUST>CCD>MTF3-M1/M2/M3/M4/M5/M6/M7/M8/
          After that, finalize the setting in the following mode.
          COPIER>ADJUST>CCD>CCD-CHNG
          a-5.Value of copyboard sub scanning magnification adjustment
          COPIER>ADJUST>ADJ-XY>ADJ-X-MAG
          a-6.Value of Pascal offset (black) adjustment
          COPIER>ADJUST>PASCAL>OFST-P-K
          a-7.Value of 100% color displacement correction
          COPIER>ADJUST>CCD>100-RG/100-GB
          a-8.Value of 50% color displacement correction
          COPIER>ADJUST>CCD>50-RG/50-GB
          • dilip_22
            • Sep 2011
            • 20
            duplex copying problem in iR2520 canon
            Hey friends ,
            I am facing a prolem when duplex copying is doing, But one sided copy is ok, please see the attachment and advise me.
            thanks Scan2.PDF
