urgent help needed with folding problem on Booklet Finisher A1 on IRAC9000
  • seniortech
    • Dec 2007
    • 180
    A customer of mine is using his machine to print a single sided A3 sheet and then fold it in half (half fold) to effectrively make a single page booklet, he wants to run 3000 of these exiting and stacking them in one of the finisher trays however whatever he does the machine will not let him do this telling him that it is not possible (cannot remember the exact phrasing, sorry) even trying to run a single sheet through the ADF the job will not print. you can however make prints using a half fold on A4 landscape to make an A5 leaflet and output into finisher tray. I have tried the job on another machine with identical configuration (but older firmware) and got the same result.
    Something is now telling me that I simply cannot run this type of job on this machine. please can someone tell me what I possibly need to do or configure to get the machine to simply half fold an A3 sheet of paper.
    Many thanks
  • teckat
    • 16083
    Re: urgent help needed with folding problem on Booklet Finisher A1 on IRAC9000
    need exact message_
    is the option grayed out ??
    so u can perform the same exact job on the other same printer model with older firmware ?
    simple solution= revert printer to that firmware ver.
    • seniortech
      • Dec 2007
      • 180
      Originally posted by teckat
      need exact message_
      Hi Teckat
      No the option is not greyed out, at first glance it almost looks as if A3 half folding is not supported, I will have to come back to you with the exact message, it's not an error/service message, I will speak to my customer tomorrow.
      The machine with the older firmware would not half fold either???
      • teckat
        • 16083
        Number of trays 3 trays
        Tray capacity (Non Collate) Tray A: A4/A5R 1,500 sheets, A3/A4R/SRA3/13"x19" 750 sheets
        Tray B: A4 2,500 sheets,A5R 1,250 sheets, A3/A4R/SRA3/13"x19" 750 sheets
        Tray C: A4/A5R 250 sheets, A3/A4R 125 sheets, SRA3/13"x19" 30 sheets
        Staple position Corner, Double, Booklet Stitch(Booklet Finisher only)
        Staple capacity(64-80g/m2) 100 sheets (80g/m2)
        Booklet Stitch Specifications- Paper size: A3, A4R, SRA3, 13"x19"
        Staple capacity: 20 sheets (80pages, 64-80g/m2)
        Paper weight: Body paper 52 to 105 g/m2, Cover paper 52 to 300 gsm
        STAPLE FINISHER-A1/BOOKLET FINISHER-A1
        • seniortech
          • Dec 2007
          • 180
          need exact message_
          Hi Teckat
          Exact message on machine display is:
          Only A4 R and LTR R can be used for half fold
          • teckat
            • 16083
            Originally posted by seniortech
            Hi Teckat
            Saddle Stitch sizes ???
            13x19 = A3+ = 483 mm x 330 mm = Super-B
            SRA3 = 450mm x 320mm
            12x18 = 305 x 457 mm = Architectural-B
            11x17 = A3 = 432 mm x 279 mm
            Legal = 216 x 356 mm
            Letter-R = A4 R = 279 mm x 216 mm
            Firmware issue !!!!!!!!!!!!!!!!!!!!!
            • seniortech
              • Dec 2007
              • 180
              Hi teckat
              Thanks for your help so far
              If this is indeed a firmware issue, this is one almighty oversight by Canon, do you know of others who are having the same problems and do you know if canon are aware of this problem?
