Ethernet board pcb assembly
  • adhy
    • Feb 2011
    • 109
    [Misc] Ethernet board pcb assembly
    hi i need some information about ETHERNET BOARD PCB ASSEMBLY(FG6-5964-000) can i put this part into IR 5000 standart? i just try it but they give me an error 740-0002. i intend to upgrading the IR 5000 using my new laptop using the LAN connection. am i do wrong? please to all senior tech help me
  • sx633
    • Sep 2011
    • 49
    Re: Ethernet board pcb assembly
    You can't just fit a NIC to a 5000 and expect it to work. From memory I am pretty sure you will need to fit a new Boot ROM and will certainly need to upgrade the system software to the "N" version.
    Hope this helps.
    • charm5496
      • 2387
      If you are adding the NIC just for the sole purpose of upgrading the firmware you are probably going to be dissapointed as it doesn't always function with all the files and you get a ton of errors. The best way to upgrade the IR-5000 is still with the parallel cable or nethawk cable. And that is the board you want to install for network connectivity.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        And if you have no laptop with the parallel port, or the Nethawk cable, there are plenty of regular PC's that still have the port, you may even be able to use one of the customers PC's. Just make sure the parallel cable is IEEE-1394 compliant...
        • teckat
          • 16083
          READ THIS PDF-----
          iR5000 SERIES NIC BOARD TP04.pdf]
          October 6, 2010
          All imageRUNNER-iR Series
          E740 Codes and the New Style Ethernet Boards (NICs)
          Error :
          Getting an E740 code on the copier LCD screen.
          Workaround :
          Please be aware that the information presented here is only applicable to the models listed.
          The copier must have the new style Ethernet Board PCB (NIC) installed. If the copier's firmware (system software) is not up to date, an E740 code will be displayed when the new style NIC is installed in the copier. The solution is to simply update the copier's firmware to the latest versions.
          UPDATE:
          There is a newer Ethernet PCB for the imageRUNNER Series for problems connecting to Cisco Power Over Ethernet (part number FM1-0196-000).
          Ethernet Board PCB (NIC):
          Original Style - part number FG6-5964-000
          Newer Style - part number FG6-9898-000
          Newest Style - part number FM1-0196-000
          With this new NIC, there are some newer firmware versions needed or the E740 code will still display. This NIC CANNOT be installed on the old style iR5000. Here are the versions needed for FM1-0196-000:
          Engine
          System Software
          imageRUNNER 2200/2800/3300
          42.03
          imageRUNNER 3300i
          25.02
          imageRUNNER 2220N/2220i/3320N/3320i
          34.05
          imageRUNNER 5000d/6000
          81.03
          imageRUNNER 5000i
          9.01
          imageRUNNER 5020/6020
          55.06
          imageRUNNER 5020i/6020i
          55.06
          imageRUNNER 7200
          82.04
          imageRUNNER 8500/85
          82.04
          imageRUNNER 105
          82.04
          Old Style - part number FG6-5964-000
          New Style - part number FG6-9898-000
          Minimum firmware versions to recognize the New Style Ethernet Board (FG6-9898-000):
          Model(s): MN-CONT (system software): BOOT-ROM:
          imageRUNNER 2200 / 2800 / 3300 41.01 or higher 23.40 or higher
          imageRUNNER 3300i 24.02 or higher 23.40 or higher
          imageRUNNER 2220N / 2220i / 3320N / 3320i 33.01 or higher 24.42 or higher
          imageRUNNER 5000 19.02 or higher 14.54 or higher
          imageRUNNER 5000d / 6000 74.02 or higher 23.40 or higher
          imageRUNNER 5000i 44.02 or higher 23.40 or higher
          imageRUNNER 5020 / 5020i / 6020 / 6020i 54.03 or higher 24.42 or higher
          imageRUNNER 7200 / 8500 / 85 / 105 81.02 or higher 23.40 or higher
          Related Technical Publications:
          For more detailed information, please see the appropriate attached Technical Publication:
          TP05 120a.pdf - All imageRUNNERs (New NIC for Cisco Power Over Ethernet)
          TP04 228.pdf - imageRUNNER 5000 / 5000i / 5020 / 5020i / 6020 / 6020i.
          TP04 227.pdf - imageRUNNER 2200 / 2800 / 3300 / 3300i / 2220N / 2220i / 3320N / 3320i.
          TP04 226.pdf - imageRUNNER 105 / 8500 / 85 / 7200.
          • teckat
            • 16083
            imageRUNNER 5000/ 5000D/ 6000D/ 5000i/ 5020/ 5020i/ 6020/ 6020i
            Ethernet Board PCB (NIC) Changed from Old to New Style
            Requiring the Latest System Software to Prevent an E740 Code
            As the old-type Ethernet Board PCB (NIC) cannot be obtained anymore, a new-type Ethernet Board PCB
            will take it’s place. With this change, a System Software & Boot-ROM upgrade will be required.
            POINTS TO NOTE ABOUT SERVICE WORK:
            The new-type Ethernet board cannot be recognized when it is used with earlier versions of System
            Software other than the following:
            imageRUNNER 5000: System Software Version & 19.02 BootROM Version 14.54 & later
            imageRUNNER 5000D/ 6000D: System Software Version 74.02 & BootROM Version 23.40 & later
            imageRUNNER 5000i: System Software Version 44.02 & BootROM Version 23.40 & later
            imageRUNNER 5020/ 5020i/ 6020/ 6020i: System Software Version 54.03 & BootROM Version 24.42 & later
            Without these System Software & BootROM upgrades, a symptom of E740 will occur. When replacing an
            old style Ethernet Board PCB on copiers with the new type ethernet Board PCB, please be sure to upgrade
            the System Software, and Boot-ROM to the above version levels or later respectively.
            You will NOT have the ability to enter the IP Address and E740 code will occur if the System Software & Boot-ROM are not upgraded to at least the specified versions above.
            ‘CAUTION!’
            SERVICE PARTS:
            Description----------------------Part Number-----Interchangeability
            Old Ethernet Board PCB Assembly--FG6-5964-000----Yes
            New Ethernet Board PCB Assembly-FG6-9898-000----Yes
            • kuby
              • Oct 2007
              • 1409
              You the man Teckat
              • teckat
                • 16083
                ELVIS.jpgTHANKS, GOOD LUCK
                • adhy
                  • Feb 2011
                  • 109
                  i should thanks to all senior tech ..after read all information it's open my mind that i so stupid..i will tried those all paces and will keep in touch on you. best regard
                  • bakaoni666
                    • Mar 2010
                    • 56
                    MN-CONT 81.03
                    BOOT-ROM 26.44
                    Still E740-003
                    I put the ethernet It became E740-002
                    Please Help..
                    • charm5496
                      • 2387
                      a model number would be helpful, but here is some info that might assist you:
                      Engine System Software
                      imageRUNNER 2200/2800/3300 42.03
                      imageRUNNER 3300i 25.02
                      imageRUNNER 2220N/2220i/3320N/3320i 34.05
                      imageRUNNER 5000d/6000 81.03
                      imageRUNNER 5000i 9.01
                      imageRUNNER 5020/6020 55.06
                      imageRUNNER 5020i/6020i 55.06
                      imageRUNNER 7200 82.04
                      imageRUNNER 8500/85 82.04
                      imageRUNNER 105 82.04
                      • teckat
                        • 16083
                        good point charm5496
                        did u know this poster >posted same question in here>
                        http://www.copytechnet.com/forums/ca...740-002-a.html
                        I gave them the same exact info/ with a pic of pcb. with no reply
                        • bakaoni666
                          • Mar 2010
                          • 56
                          Thanks Teckat...the machine works just now..
                          I try to change the Flashrom from other machine and upgrade it to ver 23.44
                          is the broken flashrom can cause E740?
                          • teckat
                            • 16083
                            Yes, GoneFishing2.jpggood luck~~~~~~~~~~
                            • charm5496
                              • 2387
                              why do they double post?!?!?!
                              looks like you have him on the right path....have a merry christmas my friend!!!
